Question about Frigidaire FEF366 Electric Kitchen Range
Red light stays on indicating burner is on when burner is not on.
Red light stays on indicating burner is on when burner is turned off. stays on all the time
  • kevinporter5 Jul 26, 2009
    its not the light indicating that the top is hot, that one goes off after the top cools down. its the one indicating that a burner has been turned on that dosn't go off at all.
  • phil Jul 29, 2013
    lite stays on continully
    President:
  • 2,559 Answers
It should stay on after the burner has been turned off and remain on until the top has completely cooled down,if it stays on and never goes off, the thermostat for one or more burners is faulty and will need replaced.
Posted on Jul 26, 2009
  • Randy Hough
    Randy Hough Jul 26, 2009
    That would be one of the infinite controls are not turning completely off or the main board is going bad.
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: the indicator light for the burners stays on all the time
Check this out
Posted on May 10, 2010
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
heatman101
Dec 25, 2010 | Microwave Ovens
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
I have a GE stove that has a red light for HOT SURFACE
The control switch for the right front burner is bad. A new switch will solve the problem.
The situation,while annoying is not dangerous.
Feb 18, 2010 | GE Kitchen Ranges
Hot indicator surface light will not turn off on maytag smooth top oven cre9600bce. always stays red even when oven or cook top not in use. What part is needed.
I had the same problem, but I found out it was only when one particular burner was turned on. I waited for the problem burner to cool, then took the fist of my hand and tapped on the burner itself and the light goes out every time. Works like a charm..probably a loose connection with that one burner.
Jan 30, 2010 | Kitchen Ranges
Red light indicating a plate is hot stays continuously on.
I assume this is a smooth top model? One of the sensors on a burner is bad and can be replaced. It involves removing the top adn disassembling the burner. Not difficult by my standards but delicate work that requires some knowledge of electrical components.
Eric
Nov 12, 2009 | Kitchen Ranges
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Kenmore stove surface unit light stays on
When the indicator light does not shut off when the burners are turned to the off position, this indicates one of the infinites switches are shorted. If comfortable with electricity, unplug the unit and remove the rear cover exposing the infinite (burner) switches. Using a bright flashlight, shine directly on one of the switches and you will see the following markings. L1 - L2 - H1 - H2, and then the Letter P. This letter P is for the pilot light. Since there is no way of determining which switch is shorted, remove the wire from the letter P on one switch. Isolate the wire removed so it is not touching anything. Place a piece of black electrical tape around the end to be safe. Next, plug it back in. If the light is still lit, move on to the next one until you have found the switch that once the wire is removed, the light does not light anymore. Replace that infinite/burner switcha nd all is well. If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Kitchen Ranges
Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Mar 05, 2008 | GE JBP64 CleanDesign Electric Kitchen...
Frigidaire FEF366 Electric Kitchen Range Logo
1,438 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
