Question about Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive
No power Western Digital Elements WD5000E035 500GB drive The drive has no power. The power adapter appears to work from the socket: the light on the adapter turns green, until I plug it in to the drive, at which point it goes dark. I?ve tried disconnecting everything, rebooting the machine, and reconnecting ? no result. My questions: Is the problem likely to be with the adapter, or within the drive itself? If the former, where do I buy a new one? If the latter, how do I get it repaired in order to at least access the data and transfer it across to a new drive?
  • TheLastLion Aug 09, 2009
    The drive: http://www.wdc.com/en/products/products....
    Possible solutions:
    From the Western Digital FAQ:
    Why is my external hard drive having a power issue, or is not being recognized in Windows or My Computer? http://wdc.custhelp.com/cgi-bin/wdc.cfg/...
    Again from the FAQ (hoping it won't be necessary):
    How can I move or copy files from one hard drive to another in Windows? http://wdc.custhelp.com/cgi-bin/wdc.cfg/...
    Possible solutions:
    Problem Solver:
  • 5 Answers
Same thing happened to me with my WD Elements. Took it to Geek Squad and turns out that I need a new hard drive casing.
Posted on Aug 17, 2009
  • 181 Answers
Try it on a diffrent computer to see if it works if the same remove it out of the bow and plug it straight in to you computer as a slave setting the jumps
Posted on Aug 08, 2009
2 Suggested Answers
ajitvd
  • 89 Answers
SOURCE: No power Western Digital Elements WD5000E035 500GB drive
its with adapter... you would get it in any computer service shop
Posted on Jul 29, 2009
The wd elements 1023 not recognize by my windos 7 32
Will my elements WD5000 Co35-000 work i.e. compatible with Windows 7. Also where can I purchase an AC adapter for this model.
Nov 15, 2013 | Western Digital Elements powered by WD 320...
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
Oct 28, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Feb 22, 2010 | Western Digital Elements powered by WD 320...
AC Adapter blinks once, but no power getting to hard drive
These drives are known for lunching the power supply within the unit itself. Depending on you PC configuration, you may wish to do the same as I did when mine went. The drive itself is a standard 7200 sata drive. If your motherboard has sata capability, and/or a spare sata connection, you can slave the drive into your pc, and end of problem.
Sep 19, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My ac adapter green light turn off when i turned on the hard drive
Chances are you have a faulty power supply. Contact Western Digital at their website for an RMA. The website is
http://support.wdc.com/warranty/index.asp?wdc_lang=en
Sep 02, 2009 | Western Digital Elements powered by WD 320...
Jul 26, 2009 | Computers & Internet
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
Western Digital Elements HD doing a clicking noise and no access
It might be the power adapter. I had one of these and two Maxtor external drives that just clicked that way and it turned out their adapters were bad. You can check with another adapter if you can borrow one from another drive, or use a replacement from Radio Shack. Make sure you get the same voltage and current rating marked on the original.
If the adapter isn't at fault, the small circuit board in the enclosure may be the trouble. You can remove the drive from the case and connect it to directly to a computer power supply to see if spins up properly.
If the drive still doesn't spin, it's bad. This is a common way for a drive to fail. Unfortunately, this leaves you with a drive that you can't read. Hopefully you've backed your important data up on CD or DVD.
May 21, 2009 | Western Digital Elements powered by WD 320...
My drive won't start up
Don't use a power strip or surge protector.... try to connect the power supply adapter directly to a wall socket. Always safely remove hardware after use
Aug 14, 2008 | Western Digital My Book Essential Edition...
Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
2,743 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
