Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Fan runs all the time - freezer frost build up
I have the same problem with my french door LG - the fan is constantly running if the doors are closed. When a door is opened, the fan stops. There is frost build up on the contents within and on the plastic pieces in the freezer, as well. The light in the freezer gets stuck in the 'off' position and needs to be manually tripped for it to work at all. I have checked to see if the contents in the freezer could be the culprit, but there doesn't seem to be any obstruction!
The unit is three months old.
  • 76 Answers
The fan should cycle during recovery period after you opened the unit and then shut off. Make sure there is plenty of space around the unit for ventilation. If you've done this and you said it's 3 months old? Call for warrantee service.
Posted on Jul 26, 2009
LFX 28978 LG French door refrigirator too warm, frost in the back of freezer
call for service, could be a computer board, fan motor, or defrost system. cheaper in the long run to call for service
Apr 30, 2012 | LG LFD25860TT Titanium French Door...
Model LFX25960TT is showing an error code of Er FF. What does this mean?
The control board is not seeing a feedback signal indicating that the freezer fan is running. Check for a build up of frost in the freezer compartment which may be preventing the fan blade from turning.
Feb 26, 2011 | LG LFX25960ST Stainless Steel French Door...
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Frost on back wall of freezer
There is a door that is not closing 100% of the time. There is warm moist air entering the fridge and building up on the back wall.
Make sure all doors are closing. Sometime the bottom door will close on one side but not the other.
Good Luck.
Jul 24, 2010 | LG LFX25960 Bottom Freezer French Door...
Just starting not keeping things cold
If there is frost on the wall of freezer, you have a defrost problem, and not enough air is circulated due to frost build-up. If no frost and all fans and compressor is running, you have a sealed system failure. Time to replace refrig.
Jul 02, 2010 | Amana AFD2535DES French Door Refrigerator
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Why is freezer frosting? It causes the compressor to run loudly
check fan on freezer area and make sure it is not ice build up and hitting the fan and if it is this then you need a heating element on the evap.....
Aug 12, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
697 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
