Question about Kenmore 500 6953 Dryer
My washer drain pipe is overflowing on my floor
When my washer goes to drain, bith cycles, it overflows my out pipe and leaks a bit on my floor each time this problem is conciderably new PLEASE HELp!
    Sergeant:
    Champion:
  • 246 Answers
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
Posted on Jul 26, 2009
What causes water to overflow in drain pipe when rinsing?
Probably 1 of 2 things. First you may have a partial clog of the drain, can be a pain to unclog, snaking the drain usually helps. The other could be the line you have running into the drain could be pushed down too far where its lodge funny in the drain pipe, I would pull it up and out of the drain pipe a little to give it a little more room.
With this said, I'm betting you have a partial clog in the drain.
Feb 15, 2013 | Maytag MVWB850WL 28" Top-Loader Washer 4.0...
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
The water drains too fast and overflows
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Washer is leaking out of overflow tube
first
check the drainage pipe, the hose goes into and make sure its not clogged, once you know there are no obstructions reattach the drain hose. be sure it goes a couple of inches into the pipe but has a little space for air flow between hose and pipe. I this doesnt fix the problem the hose made need to be raised, it should enter the pipe several inches higher than the washer. Hope this helps
Nov 28, 2009 | General Electric WHDSR209DWW Top Load...
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Washing machine drains; then drain pipe overflows
Try some drano other chemical drain cleaner. If there is a build up lint or other biodegradable material in the drain pipe the drano should remove it.
BTW how long has it been doing this..... did it just start?
Jul 07, 2009 | Kenmore Washing Machines
Water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
May 08, 2009 | LG WM0001HTMA Front Load Washer
Rinse pipe overflow
Depending on how your drain system is plumbed where you live.. many homes use a 'trap' .. meaning a place where water remains to keep sewer gas from getting back into your home.. If your house is set up with this ( and it may be on the wall or in the floor).. you may have a blockage there that won't allow water to drain fast enough and the pipe fills up and leaks onto your floor.. Hope this helps you...
Sep 24, 2008 | Washing Machines
Kenmore 500 6953 Dryer Logo
136 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
