Question about Coleman Cable Power Inverter PMP1200
Power going up and down
Hello i have a durite 1000w inverter and it will charge a 30w torch no problem but when i put on a higher load like a 500w halogen work light it just squeals and the light goes from dim to bright constantly i.e the power seems to be there then no power etc etc.
Have looked inside but cant see anothing wrong....any ideas of the components i need to change or test.
Many thanks.
  • 5,603 Answers
An incandescent lamp that is cold takes approximately 10 times the running current initially. The inverter MAY not be able to start the 500 watt lamp if its protection circuits sense the very low starting resistance of the lamp.
Test the inverter on some other device first.
Posted on Jul 26, 2009
I have a durite 1500 watt inverter and it has stopped working is there a fuse inside ?and if so how do i change it
Could be a number of reasons it quit. You crossed the power wires blowing the diodes for protection, or you over loaded it an blew a MOSFET, the fuse blew, or a number of things. You have got to be more specific.
May 07, 2017 | Inverter Electronics - Others
Overloaded inverter will not power up
Have you checked the voltage going to the inverter? Sounds like you may have exceeded the load that he inverter can handle but not enough information to confirm that from this end. You mention "plugged into my van battery", possibly you have this plugged into your Cigar Lighter? Mega fuses are usually really high amperage fuses, much more than the inverter could blow and save the inverter. The fuse should be matched to the load and about 50% higher. If the device is rated at 10 amps, a 15 amp fuse will provide protection where a mega with 500 amps will act like no fuse at all to the inverter.
Apr 12, 2017 | Inverter Electronics - Others
My inverter when power cuts output pins gets revers and when power returns again i have to change the output pin terminals .
inverters go back too 1965,(i sold the then)
WHY NOT BE CLEAR
what you have, make and model,
what is your DC side source.
what is on the output side A/C JACKS
WHAT IS Your load
what power is this inverter, 50watts 500w 1000w or more:?
post a photo of,
it's not a computer.
Feb 13, 2017 | Power Computers & Internet
Just connected my durite 1000w inverter to battery wrongly got a big spark now will not work
Check the fuses . Look inside for a fuse on the circuit board. There may be some burned up components inside too.
Jan 26, 2015 | Electronics - Others
Durite inverter
If the unit doesn't have an external fuse and it doesn't reset itself after an overload, it possibly has an internal (onboard) fuse that needs replaced. Possibly de-soldered and re-soldered...
Feb 01, 2014 | Vector Electronics - Others
Overload indicator comes on without any appliance attached
The battery may be new- but how much charge does it have? The inverter has a high and low battery warning.
If the inverter has no load upon it, it may see the battery potential as high. so if you put a load on it such as an incandescant lamp, in parallel to the inverter, and as an inverter load it should circumvent the warning. Then it is a matter of fine tuning the setup.
Dec 29, 2011 | Electronics - Others
Is my inverter working correctly?
An inverter should work immediately.
Jun 10, 2010 | Electronics - Others
Hi, i've got a skytronic 300w soft start inverter making loud beep and then cutting out. I know its one of the safety cut outs but not which one. can it be repaired ? thanks
If your appliance draws over 300W or if your 12 v battery charge is low you will get a loud beep warning. Do you get the same beep with a low current appliance like a lamp? Make sure your battery has a good charge.
Some appliances have huge draw at start up even though they are rated under 300w your inverter may not be able to start.
Also some electric motors don't like modified sign wave inverters.
What are you trying to run and what is its rated watts?
I had my inverter beep when I had it connected via a cigarette lighter plug but when I used a connection straight to the battery it worked fine.
I was running a 500w grinder on a 1000w el cheepo inverter.
Aug 17, 2009 | Electronics - Others
No power output from my vector 1000w inverter.
Buy a different brand of inverter. Yours has developed a short which the protection circuit is catching. It then tries a restart but fails all over again. Most likely o/p short which looks like an overload to the inverter.
Jan 30, 2009 | Electronics - Others
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
Coleman Cable Power Inverter PMP1200 Logo
313 people viewed this question
Top Coleman Cable Electronics - Others Experts
Are you a Coleman Cable Electronics - Other Expert? Answer questions, earn points and help others
