Question about Toshiba Televison & Video
Why does My Toshiba TV keep turning itself off and on all by itself
I can turn it on with the remote over and over but it just turns itself off every 5 to 10 minutes.
    Top Expert:
  • Toshiba Master
  • 85,111 Answers
You have a shorted circuit board in the TV somewhere.
Posted on Jun 15, 2017
Testimonial: "I have three boards on the TV. I have replaced the main board with no change leaving two more boards. It must be one of them with a faulty relay and I can't see it. It just turns itself on and off whenever it wants to."
  • Marvin
    Marvin Jun 15, 2017
    I don't guess, unless you have the test gear and the repair manual you just have a money pit. I would just count the loss and replace the TV. Just my opinion.
SOURCE:
The alarm system on my 2001 Volkswagen Jetta GL keeps turning on by itself
You must have the dealer keep the car until this fault occurs and then scan the security system to see what is causing the triggering of the security system. It is very possible that the drivers door ajar switch or latch switch is defective and it triggers a false tampering signal.
Sep 28, 2012 | Cars & Trucks
Replace the bulb and the tv has pitcure now, but after 1 minute turns itself off and then back on.
I'm having the same problem, I called tech support and they told me to hold the reset button for a minute and then try again, I have a universal remote so it doesn't have a reset button, :( So frustrated, any solutions please?
Feb 25, 2012 | InFocus ScreenPlay 61" Rear Projection...
Power turns off by itself once in a while. i turn
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Feb 25, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Expensive Monte Carlo ceiling fan turns on & off by itself
needs an electrican to inspect
faulty on /off switch
flat batteries/ faulty remote
or
rodents in the roof chewed wiring
Mar 22, 2017 | Monte Carlo Dryers
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
Jul 04, 2009 | Televison & Video
It turns itself on and off repeatedly
Try this:
Unplug the tv let sit for a minute while you replace the batteries in the remote and cover the IR remote sensor on the front of the TV. Cover it with a piece of black tape or a piece of aluminum foil.
Plug the tv back in and turn on.
If it no longer turns on and off by itself then you have IR interference from some other remote operated device in the room.
If it does continue to turn on and off with the IR sensor covered then it is the internal wiring/processors and will need servicing.
May 12, 2009 | Sanyo DS27510 27" TV
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Trinitron KV-2966AS turns itself off after only about ten minutes
No solution in regard to fixing it. I used my warranty and came home with another television which works perfectly.
Oct 12, 2008 | Televison & Video
Televison & Video Logo
434 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
