Question about Zhone 6211-I3-200 Router
Not connecting to its IP
The problem is what is described in the subject, I just simply cannot reach the modem as told to in the manual (
My IP/subnet settings are correct, I tried with both usb and lan connections and even reset the model couple of times and restarted the computer.
I am completely at loss :(
  • ipal Jan 03, 2008
    my router alarm light stay on red and i cann't get on
  • Anonymous Jul 13, 2008
    Same problem. i can access the internet, but cannot access the modem menu and settings. i am not using a router, just the modem
  • 173 Answers
, as u say that youy ip setytings are correct, did you check your ip address, if first check your ipaddress,
to check your ip:
Click start > run > type cmd > and click ok
you would see a black window, and in the window type ipconfig and hit enter, you would fing your ip address,
check if you are able to ping your ipaddress i.e to check connectivity, in the same black window, type ping (your ipaddress)
for example if your ip is, then type in
ping and hit enter you would find four replies then it seems your connectivity is good,
then proceed further
Click start > run > type > and click ok
it would prompt for the user name and passwd, so that you can login to the setup page
Posted on Nov 23, 2007
Router crashing
Router Technical Support includes router set-up, password reset, security, configuration, settings, Wi-Fi security etc. of any router. Call : 1-800-243-0019.
Apr 13, 2017 | Motorola SURFboard Computers & Internet
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
Need ip address subnet mask number gateway number and dns server number
If the ip address you need is the Internet IP address, this is assigned by you service provider.
If you need an internal ip address, have a look in the modems configuration window.
This window is accessed using internet explorer and typing in the local address of the modem, usually this is so enter this number. If this does not work, go to the modem manufacturers website and in the support section should be the manual (if you dont have one) and in the manual will be the ip address to access the modems configuration pages.
You must undertake these steps with your PC connected to the modem using a network cable, this will not work if you try this using a wireless link.
Usually, the admin and password details are admin admin. So type admin in the name section and admin in the password section.
Once you access the configuration area, navigate to the DHCP area and turn DHCP on.
DHCP stand for Dynamic Host Control Protocol. This simply gives an internal ip address to all the machines connected to the network.
Once this is done, save and reboot the modem and your PC.
Next,click on start and then run and enter CMD into the run dialog box.
When the text window opens, type in : ipconfig /all
dont forget the space between ipconfig and the / symbol
This will give you a list, in this list is the gateway ip address etc.
Usually, the DNS address is assigned automatically by your service provider but if not, you may have to contact them to get this number.
If you are trying to connect a second PC to the modem, all these details will be entered for you as long as you have "Obtain ip addresses automatically" ticked in the properties window of network connections. This is under the network connections applet in control panel. make sure everything is set to automatic.
Jan 13, 2011 | Arris SURFboard SB4200 Modem
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
My 2wire router will not connect to my nintendo ds wifi system.
The DSi only works with WEP encryption. The 2Wire and most other newer routers use WPA encryption.
Simply logon to your router with a web browser. The default IP for it is but it might be different, just check the manual or internet for the IP. Go to "Home Network" then "Advanced Settings" and change the security from WPA to WEP and save.
Thats it!
Hope that helps.
Nov 18, 2008 | 2wire (1000-000057-000) Modem
My ip address need reset
to reset your ip address simply unplug your modem and router, turn off the computer, turn on the computer with out pluging the router and modem back in, turn the computer off , plug the router and modem in wait for the lights to come on and then turn your computer on.
May 14, 2008 | Black Box IP Address Translator With...
Old man with play station 3 problem freezeing after hitting start
Well, actually, the one you have, linksys is the least problematic. The particular model you have also seems to work. I've seen many threads on various forums( while researching an answer for your issue), where Belkin routers were the most troublesome.
Simply ignore the warning and try the game and see if it works or not. If it works, great, if not, then well, nothing much has changed :)
Also, try the ip configuration without the router, with a direct connection, and let me know how it goes..
Apr 30, 2008 | Computers & Internet
D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
Oct 24, 2007 | Computers & Internet
Installation problem with edimax 6104kp
Hi Omdi,
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Best regards,
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Connecting 2 computer thru DI-514
Well I believe wat ya need to do is simply obtain a NEW "Account" with NEW Logon & Password with a NEW Internet Service Provider. Then you set up the modem to connect to the new ISP, at the NEW ISP's address, with the NEW Password & Logon. When you got the modem ya should have got a "Setup" CD that should walk ya thru the connection routine... Below is a link for a "Users Manual" that should help you get connected.
Aug 15, 2007 | D-Link DI 514 Wireless Router (DI-514)
Zhone 6211-I3-200 Router Logo
172 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
