Question about Fuji FinePix Z10fd Digital Camera
Camera wont connect to computer anymore, use to but now not working. 1st says its in use try again later and then says not connected check cables..
    Sergeant:
    Champion:
  • 246 Answers
Did you try uninstalling program by going to Control Panel > Add or Remove Programs > look for Fuji FinePix and click on Remove, then re-install with CD Disc provided with camera.
Posted on Jul 26, 2009
Camera wont acknowledge computer or visa versa
did you mean that your computer does not detect your camera when you connect to it? How do you connect your camera to the computer? by usb port? try the following, one by one:
1. check by connecting to a different USB port in your computer.
2. check by using a different USB cable.
3. check by connecting to a different computer.
4. if your camera came with a disc - install it in your computer and then try again.
which operating system are you using - XP? Vista? Win7?
Nov 18, 2010 | Computers & Internet
My battery wont recharge when i plug it into the computer
IMPORTANT: To function properly, your Walkman® player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media® Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
NOTE: If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below: Check for available space on the player using Windows Media Player or My Computer . Restart the computer. Check the connection status again and try to sync the player. Check that the USB cable is firmly connected to both the computer and the player. Check the connection status again and try to sync the player. If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable. Check the connection status again and try to sync the player. If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer. After the computer restarts, connect only the Walkman portable player and test the connection again. If the player is still not recognized by the computer, try a different USB port. Check the connection status again and try to sync the player. Under the Common settings menu of the player, format the player using the built-in Format utility. Check the connection status again and try to sync the player. Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system. If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later. If you did not have the latest service pack, test the connection status again after it has been installed. If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Sep 22, 2009 | Sony Walkman Video NWZA818 MP3 Player
My USB cable is playing up!
Usually this thing occurs because of "Not safly removing the Hardware" (Cable, in your Case) or if the cable is just plugged-in and out frequently.
So try to Plug it properly, it shouldn't be loose.
And once this Unrecognition occurs, usually restarting your PC can solve the Problem.
Also check that your connecter and port isn't loose, that makes the cable to Connect/Disconnect.
Regards, Waqar.
Sep 13, 2009 | Sanyo Xacti VPC-T1075 10MP Digital Camera...
My Dimage Z20 can't upload photos onto my computer anymore. It used to show up as a drive on "My Computer", now it doesn't. Is this a problem with power cord? Camera works fine.
It could be - or it could be a problem with the PC.
Connect the camera to the pc, go into device manager (right+click on My Computer> down to Device Manager) and see if it is registering a problem.
Delete the camera from device manager (highlight it, press DEL), disconnect the camera from the PC. Power cycle the camera, then connect it back up - you should see the computer finding the camera again.
If not, check a different computer or buy a new cable,
Jun 29, 2009 | Konica Minolta DiMAGE Z20 Digital Camera
Camera cannot connect to pc anymore
yeah it could be the cable,try connecting it to other usb ports as well just to check if its not the usb port..
Jan 09, 2009 | Olympus Camedia C-3030 Zoom Digital Camera
Communication Error
Try connecting the camera to another computer. Is the camera reading the same error? If not, it's a computer issue.
If the camera is reading the same error, see if there's a way to restore camera back to the factory settings, and try all over again. Good luck :)
Apr 07, 2008 | Fuji FinePix S5100 Digital Camera
Pentax EI-100 not downloading pictures
Check the connecting usb cable that connects the camera with computer. Excessive usage causes cables breakages.
  1. Replace the usb cable with a new one available at a very low cost in market.
  2. Try other Usb ports on computer to plug in the camera
Hope it works. If not contact me again
Mar 28, 2008 | Samsung Digimax S730 Digital Camera
Speakers in monitor wont work
hi there, 1st check the connection of cable speakers. then check the volume control, switch it mid range setting. then check the hardware device if there is no conflict with any device. try to reset your system once again and if still same problem, you may have a Speaker problem, maybe the connection inside your monitor with the speaker has a loose connection or some electronics part failure. TY
Dec 23, 2007 | HP vs15 15"LCD Flat Panel Monitor
Fuji FinePix Z10fd Digital Camera Logo
451 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
