Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
My sony trinitron is 14 years old. has no picture, sound is fine
I turned it on the other day and both picture and sound were fine. I left the room for a moment and when I returned the sound continued fine but there was no picture - a black screen.
  • Sony Master
  • 586 Answers
In this situation many possibilities could be there like:but one thing is sure that the area of problem is "Vertical Section"
1-PF could be short/open
2- Collector volts are not present due to open/short
3- Capacitor could be popped.
If you are tech person then check the Vertical Section and you will find the caused component.
And if you are not an expert then i suggest you to contact any expert because fault finding is a bit difficult and can only perform by an expert.
Thanks for using fixya.
Posted on Jul 26, 2009
My Sony Wega Trinitron KV-32HS20 does not tun on and the standby light flashes 4 times. I can hear the sound but no picture and the it turns off automatically after a few seconds.
This is a tip I got from a tech bulletin.
IC600 output pins 14, 15, 16, all have aprox 130v (all should be higher) until relay clicks
then they drop off. 200v line goes up to 50v, 135 goes up to 40v.
Checked D611 (135v rectifier) it was fine. Checked D615 (It's labeled D601 on the board)
it was shorted. (D615 is the 19v rectifier for the Audio B+) Removed D615 set power up
and has good picture with no sound.
Sep 08, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Dec 29, 2007 | Televison & Video
Help with sony trinitron problem
Are you serious? You have used that television... in particular that CRT well beyond its predictable lifetime.  Congratulations.  Those are early symptoms of CRT failure.  Your screen may turn green very soon also.  It will occur any moment now.  It is not cost-effective to repair.  Welcome to the next generation.  You will be amazed and delighted with LCD, plasma or DLP technology. existencebeyondperception@msn.com
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
240 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
