Question about Refrigerators
We have a three door true cooler. All lights don't work. We checked and replaced lamp but still don't work.
  • 122 Answers
Check to see if the master light switch is on and or working properly. Some coolers have a toggle switch on the inside that can go bad aver time.
Posted on Oct 29, 2009
  • 38 Answers
Check your switches. Check for continuity on the switch while it is in the open positin. It will most likely be one or all of the switches.
Posted on Jul 26, 2009
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
Sony TV kds60a2020 replaced lamp and power lights blinks three times. Checked to make sure lamp was secure. Would light still blink if defective bulb?
have you tried making sure the lamp door is closed ... generally 3 blinks means the lamp door is not closed the door pushes a switch closed
Jun 03, 2011 | Sony KDS-60A2020 60" HDTV
Wd 52525 mitsubishi projection tv
Do the following preventive maintenance and check-up:
  1. Check the lamp cover door, it might be opened then close it firmly.
  2. Check the lamp cartridge if securely installed and tightly secure it.
  3. Clean the dust filter and provide a cooler temperature environment for the TV.
  4. Check the lamp and replace if nether of the above does not solve the problem.
    Tool needed: Phillips screwdriver
    1. Turn the television off and unplug the AC cord.
    2. Remove the front speaker grill by gently pulling
    on each side. The grill will snap out.
    3. Using a phillips screwdriver, remove the three
    screws (one on the left and two on the right side)
    that hold the recessed plastic cover in place.
    4. Remove the plastic cover and set aside
    with the screws.
    5. After removing the cover, you will be able to
    see the lamp cartridge. With the screwdriver,
    loosen the three screws of the cartridge.
    The three screws will not completely remove .
    6. Gently grasp the metal handle and pull
    straight out (towards you).
    7. Insert the new lamp cartridge securely
    into the TV. Do not touch the glass surface
    of the cartridge.
    8. With the screwdriver, tighten the screws
    on the lamp cartridge.
    9. Replace the plastic cover and screws.
    10. Snap the speaker grill back into place
    by pushing it into place on each side
    with the palm of your hand.
Aug 07, 2009 | Televison & Video
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
May 20, 2009 | True GDM-7 Beverage Cooler
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Find locate of lighting ballast in 3 door BevAir cooler
Sometimes they are in the overheade space above the cooler .. if they were inside then they would have to be HO ballasts because of the temperature .. sometimes they are in the moulding strip under the lamp itself.
Feb 24, 2009 | Beverage-Air MT27 Beverage Cooler...
True 2 door light problem
I believe that unit has a ballast tucked in somewhere in the compressor compartment. It may be easier to access from the back of the unit. I don't think it has a starter.
Dec 09, 2008 | True TD-95-38-LT Beverage Cooler
I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
Aug 14, 2008 | True TBB-2 Beverage Cooler
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
