Question about Electrical Supplies
My petrol generator is spitting flames.
I have a petrol generator and it has just been serviced. however, when ever it is running for longer than 2 mins it really over heats and spits flames. i have tried adjusting the fuel amount to the engine. any other ideas to stop this? thanks.
  • 38 Answers
I would check the floats in the carb. Be careful when pulling the bowl and float, you dont want to loose the pin and needle. If the float has gas in it, it wont be able to work properly so you will have to replace.
Posted on Jul 26, 2009
Hello my cpi Aragon GP 125. Model 2012 when been on a run sometimes the carb spits petrol back through the air filter.l have to disconnect the air filter to empty it, then it will start again.??
Hi, Bryan spitting is usually caused by a faulty accelerator pump and or nozzle, or the float bowl needle and seat leaking and overflowing through the main jet mixing well nozzle, or the air-fuel mixture screw is set to lean. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Carb spitting out petrol Pit Bike Club
125 CC carb spits fuel out intake and sputters
CPI ARAGON Service Manual
CPI Scooter Parts
CPI Aragon 125 Manual
Apr 05, 2017 | Cpi Motorcycles
Honda gx160 petrol generator,gets very hot on the muffler,then starts to backfire and flames come out of the exhaust on the muffler
You need to get the exhaust away from the generator (heat shield) because it is getting to hot and this will cause it to backfire
Dec 31, 2014 | Motorcycles
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
GAS FIREPLACE SOMETIMES TURNS ON AND SOMETIMES NOT. ALSO, IT CAN BE ON AND THEN THE FLAME GOES OUT BUT A FEW MINUTES LATER COMES ON. SUGGESTIONS?
This is a typical situation for a warn Powerpile generator. Your fireplace works by this generator generating heat from your pilot flame and converting it to less than 3/4 of a volt or 750mv. Your gas valve will eat up half of this electricity when running. So when you Powerpile gets warn it might only generate 400mv and when the gas valve turns on will bring it down below 200mv. This will start to drop once the main burner turns on and once below 150mv is no longer able to power the gas valve resulting in the main flame to go out. Minutes later the generator will build its power up again and repeat the cycle. The generator looks a little thicker than a crayon and has a red and white wire coming off it. They are easy to change but the tight spaces on a fireplace can make it very difficult.
Nov 02, 2013 | Heating & Cooling
My generator will run great and then all the sudden it will start to spit and sputter and die. After a few min you can restart it and it will run great again for a period of time and then start to spit and...
could be a ton of things. water in the gas will separate in the carb and effect it. restrictions in the fuel line/filter is another. I would look there first as it does not appear to be electrical or mechanical.
Jan 04, 2018 | Honda EU1000i Inverter Generator
I have a californian imported yamaha virago 700 leaking petrol down throgh the exhaust and spitting out when running can you tell me what could be happening thanx
It sounds like you have a dead cylinder. Without that cylinder firing, the petrol just builds up and spits out of the cylinder and into the exhaust.
Aug 24, 2010 | Yamaha XVS 1100 Dragstar Motorcycles
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Reddy heater r60
with the top off see if there is an obstruction between the fan and the back of the heater chamber.  also mounted on the backside of the combustion chamber is a hi limit with two wires coming out of it.  this connects to the flame detector which is in the flame path.  it is a copper cappillary with two spade connectors on it.  once a flame is detected, it generates a millivolt signal that opens and maintains the main gas valve. 01e527f.jpg
Oct 13, 2007 | Reddy Heater RLP100 Portable Forced Air...
Electrical Supplies Logo
150 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
