Question about Craftsman 25cc Gas Line Trimmer
No spark Craftsman 989.796060 32CC string trimmer
Can anyone tell me how to remove the clutch cover so I can get to the coil ? Thanx
  • mikeg223 Aug 02, 2009
    Thanks for the info Kennykbe!! mikeg223
  • 41 Answers
I believe there is a t20 trox screw holding the clutch cover on. Look down the hole where the drive shaft would insert. After you get that off, the clutch itself needs to be pulled off of the shaft. DO NOT BEAT ON THE END OF THE SHAFT. You may need a small puller to get it off.
Posted on Aug 02, 2009
  • Kennykbe Aug 02, 2009
    Before you check the coil itsef, make sure the wires going to the kill switch are not grounded the the body. They take the spark to chassis ground when you push the kill switch.
THE PERSON WRITING PRIOR IS CORRECT,THERE IS A TORX SCREW IN THE CENTER OF THE CLUTCH.
Posted on Aug 04, 2009
No spark crafsman 25cc 17
remove the cover from the engine to see the coil remove the small wires from the coil and spin it over if still no spark replace the coil
Aug 20, 2012 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
I have a craftsman trimmer and removal of the hub has proven difficult. Is there a method that I'm missing from the procedure?
By referring to "hub", do you mean the string head at the end or the round metal clutch drum at the end of the crankshaft? Post back as I would like to help.
Sep 30, 2010 | Craftsman 25cc Gas Line Trimmer
Putting new pull string on Craftsman trimmer
it does screw on take a channel lock to grab the clutch and turn left to remove it
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
Craftsman flipover head string trimmer. Will not start. No spark.
could be coil also could be a fouled,dirty flywheel,check coil wire
Aug 25, 2009 | Craftsman 25cc Gas Line Trimmer
No spark,craftsman string trimmer
  1. Remove the flywheel cover and pull the ground wire off of the off of the coil...
  2. Check for spark...
  • If you now have spark you have a "short to ground" some where in the in the wiring
  • If you still don't have any spark you'll need to replace the coil
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Repair a weed trimmer, How to remove the starter clutch
down in the center of the clutch there is a screw that holds everything to gether.usualy it's a torx head screw.some are reverse thread so be careful.hope this helps,let me know
May 13, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
593 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
