Question about Sub-Zero 642
Condenser needs cleaning need to get grill off 642 model
  • ted062 May 11, 2010
    by grill do you mean the pipes on the back side of the refrig/freezzer? if so they can't come off without loosing you coolent.
    Problem Solver:
  • 5 Answers
Before one can get to the two springs, there are a three screws that need to be removed first. Open the refrigerator and freezer doors. Their are two screws on the reefrig side and one on the freezer side in the jamb, at the top. Once these are removed, the SS grill can be tilted forward and the two springs removed.
The best way to clean the condenser is with a paint brush on one side and a vacuum cleaner on the other side. Gently brush teh condenser to loosen the debris. It will be sucked in by the vacuum cleaner.
Posted on Jul 30, 2009
  • Sub-Zero Master
  • 1,606 Answers
The grill is held in place by 2 springs . Just tilt outward and remove the springs .
Posted on Jul 26, 2009
Sub Zero 642 condensation back wall
FIRST TIME HE DID RIGHT THING, BUT IF IT HAPEND AGAIN DRYER WOULD NOT FIX THE PROBLEM, NEED HEAT EXCHANGER I WOULD THINK.
Oct 24, 2012 | Sub-Zero 642
Turn off code for sub zero refrig 642
Hi Dave,
On your control panel, do you have a (bell) logo? If so, press and hold that button unit the code disappears, it could take ten seconds or so, you should hear a beep. If not, turn the unit off for about 1-2 minutes by the control panel on/off switch, then when you turn it back on it should not re-appear. It depends on the model and version software in the unit on how to remove the service light and error codes. But if you continue to receive error codes you will need to have the unit looked at by a certified technician to prevent bigger problems down the road. I am a certified technician and willing to lead a hand when possible. You code 24 is a defrost over heat fault, which can happen from time to time, every-time I found this code I could never find an error in the system or defrost hardware, when I cleared the code, it never appeared again. I hope this helps.
Nov 06, 2011 | Sub-Zero 642
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
We have a flashing vacuum condenser message on our screen -- what does this mean?
It probably means that your condenser coils are dirty and need to be cleaned up. The condenser coils are the copper tubes in the back of the machine next to the condenser fan. If just vacuuming them up doesn't sufficiently clean them then you may want to get some coil cleaner from your local hardware store or whoever sold you the refrigerator.
If the condenser coils are already clean then you may not have enough airflow. Be sure you have 4 to 8 inches of free space behind the unit to provide adequate airflow.
Mar 13, 2010 | Sub-Zero 642
The tempature is set for 38 degrees, but the refrigerator is only at 47 degrees. Any ideas?
Chartigan - had this problem with my 1998 642 about 5 years ago, and had to have the condenser coils replaced twice- because the refrigerant was leaking. warning signs are: temp is more than 37 degrees [ get a fridge thermometer to monitor], food seemed to spoil quickly, and frequent notices from the display bar to clean condenser . after cleaning it 3 times in a month, when i called the service center they said that warning actually means"call service center" - arrrggghh the manual sure doesnt say that! anyhow - just something to consider, and hope your problem is not this serious.
Aug 01, 2009 | Sub-Zero 642
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer not working on sub-zero 642 model
Remove the top grille and touch the compressor on the left, above the freezer. Is it warm, can you feel it vibrating? If not, your compressor may need to be replaced.
May 10, 2009 | Sub-Zero 642
Vacuum condensor
open both the freezer and refrigerator doors, there are 4 screws at the top of the door frame that extend into the grill covering above the doors where the condenser is housed.  Remove all 4 screws, pull the grill open and then use your home vacuum to clean the dust from the condenser coil (it'll be obvious that it needs it).  Close the grill back, replace the screws and the message should go away.
Sep 08, 2008 | Sub-Zero 642
Subzero 642
if you fridge runs for 6 cycles with out a cycle off .. your vacuum condenser light will come on. you can check the evapator if there is only a frost on the top ar an Ice at the top ...you have a leak and will need to have the evapator replaced...let me know if it helps
Jun 10, 2008 | Sub-Zero 642
Refrigerators Logo
337 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
