SOURCE: my ge quietpower 2 dishwasher
HI
The door of the dryer is sealed with one or more gaskets to keep the hot air in the dryer from escaping and prevent the cool air in the laundry area from being sucked into the dryer. A deteriorated or damaged gasket greatly lowers the efficiency of the dryer. To check the gasket, hold a sheet of tissue paper near the rim of the door while the machine is running. If the door leaks, the paper will flutter. If the gasket or seal leaks, looks worn or warped, has chunks of material missing, or feels hard and nonresilient, it should be replaced with a new gasket of the same type.
THAKS/..............
SOURCE: GE Adora QuietPower II Replacement Rack Wheels?
I HAVE A GE ADORA QUIETPOWER II. WHEN THE DOOR IS CLOSED THE BEEP IS SOUNDED INDICATIN THAT THE DOOR IS CLOSED BUT WHEN I PUSH THE START RESET BUTTON NOTHING HAPPENS. PLEASE HELP
SOURCE: no water in dishwasher
check the water valve it could be bad and not be letting water into the unit...let me know and I will further assist you.
SOURCE: GE quietpower 3 dishwasher repeatedly
Please provide the full model number of the dishwasher.
Also does the behaviour change if you change the program you are choosing. Try the short cycle like rinse program. Are any of the lights flashing or staying on?
Have you turned the mains power off and back on?
SOURCE: My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
