Question about Refrigerators
Not running, we have a light on the intertnal ice maker. I have checkd the extermal fuse and it has not tripped. inside lights do not turn on, the external water dispenser and lights do not work. The refrig is 3 years old
  • 38 Answers
If your bulbs are good then you need to check continuity on your switches. Pull your switch and replace if there is no continuity on the switch in the open position. It has to be a switch or switches.
Posted on Jul 26, 2009
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
U line ice maker trips breaker
Something that powers up immediately, try any cooling fans or the solenoid. Easiest test is just disconnect anything non essential and turn on, if it doesnt trip, turn off, connect one thing and try againn. then connect one by one until it trips again and the last thing you plugged in will be faulty.
Jul 10, 2013 | Refrigerators
Turn on water light on outside of door
Can be faulty control panel causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Maytag Refrigerators
How long after hooking up ice maker does it take for the water to start running in. we have water in the door water just not in the ice maker?
Should have started to fill soon after freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice approximately every three hours. The above was in the user manual and only answers when the process begins. There is a thermostat embedded inside the ice maker that tells the water control valve for ice maker to open for approx. 7.5 seconds. Because this model has a freezer below the left fresh food section light switch has an interlock that completes 120VAC to the ice maker once the fresh food section door is closed. Defective fuse, door switch or ice maker will make operation impossible until the problem is located. Please let me know if you need assistance beyond the above here.sea_breeze_27.jpg
Thanks, Sea Breeze
Dec 16, 2010 | Amana ASD2620H Side by Side Refrigerator
Ice maker not working. Have replaced the Ice Maker and still not working. Is there a fuse for the ice maker controller or reset button? I have the Whirlpool Conquest Gold Series between 8 and 10 years...
Roger... this is going to sound way to simple. The ice maker power is cut off by the door switch. Check the door switch. 1/2 of the switch powers the light and the other half powers the ice maker when the light is off. That stupid little door switch has tripped me up several times and I work on them!!! There is one locking tab on ONE side of the (usually white door switch to pop it out of the chassis. It will have 3 terminals on it. One is a common wire, one powers the light (door open / plunger extended) and the other one powers the ice maker (door closed / plunger depressed)
Don't buy a controller yet!!!!
Thanks for choosing FixYa.
Kelly
Nov 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
The power wont come on and I checkd all the fuses. Could the fuse inside have tripped
yes beware if you replace it and it blows again then you have a dead short all the best
shaun
Aug 04, 2009 | Fisher and Paykel GWL11 Top Load Washer
Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Apr 12, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
