2003 Harley Davidson XLH Sportster 883 Hugger Logo
Bill Mccormick Posted on Jun 15, 2017
2003 Harley Davidson XLH Sportster 883 Hugger will not start
Good morning, got a hugger 2003 that won't start with the key on all lights work and horn also exception to head light and neutral and oil light and won't start even speedometer light and numbers come up
Neutral light does not come on 2000 xlh sportster
Check all the fuses, are any blown? It looks like the ones for headlight and ignition have blown.
6helpful
2answers
How can i tell if i have a sportster hugger or just a sportster 883?
The difference between the 883 and the hugger were very small. the hugger came stock with buck horn handlebars and a shorter suspension. the differences are still noticeable today between a standard 883 and and 883 low.
1992:
  • Hugger model made even lower
  • Standardized hand controls
  • Production Information:
  • XLH 883 $4,499
  • XLH 883 'Hugger' $5,075
  • XLH 883 'Sportster Deluxe' $5,559
  • XLH 1,200 $6,400
also check your vin number if you have and 883 it should read 1hd4cam........ or for a hugger 1hd4cem....
I just bought a 2003 harley sportster XLH 883 , and my horn does not work , i am not sure where or if there is fuses for this can you help me figure this one out . thank u .
I don't think your horn is on it's own seperate fuse. Usually, the horn is on the accessories fuse along with a few other things. Pull the wire off the backside of the horn. Put the prode of a test light or the lead of a volt meter in the wire connector. Press the horn button to see if you have voltage there. If so, your horn needs to be replaced.
I think the fuses are located behind the triangular plate just in front of the rear fender on the left side of your bike. If not there, check under the seat. Harley moves them around a good bit.
Good Luck
Steve
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
