Question about Boating
I have a 1990 Johnson 30 2 stroke, when i turn the key I hear clicking, I think that is my solenoid, but the starter does not engage. Background, I forgot to put the plug in the boat, some of the wires came in contact with some water. What can I do to start
  • 38 Answers
Does the battery have a good charge? If so take a screw driver a cross the posts on the solenoid with the key on. If it still clicks then you will need to replace. Make sure if its a 12V batt, that it reads 14 to 16 volts on your meeter. Your batt should always have a few more volts higher than what it is.
Posted on Jul 26, 2009
What is the problem with my 1995 dodge diesel 2500 truck it is hard to start can anyone help
your question is alittle fague, if you turn the key and all you hear is a clicking sound, then your solenoid is working fine, if you turn the key and you don't hear the clicking, then the solenoid is bad, or you are not alway's getting 12 volts from the ignition, you will then need to put a tester on the solenoid while turning the key an see if you are getting voltage to the solenoid when the solenoid is not clicking, but if the solenoid is clicking and the starter is not turning the engine, get someone to tap the starter motor with a small hammer while turning the key and see if the starter engages, if it does you have a bad spot and need to replace the starter, a qualified mechanic can find your problem in less than 30 mins. hope this helps
Aug 14, 2014 | 2002 Dodge Ram 2500 Truck Thermostat 195...
Pontiac g6 won't start not the battery could it be the starter makes no noise when key is turned?
The ignition switch sends voltage to the starter solenoid, if no neutral or brake switch is involved. It is sometimes located ON the starter. It activates a high-current switch that engages the starter. If you don't hear a click, the solenoid could be bad. Since the high current can damage the contacts, you could still hear a click and not get the starter to spin. Sometimes hitting the solenoid, or starter lightly with a wrench or hammer will realign the contacts and you can get another spin from the starter. Hitting the exposed contact on the cable that goes straight from the battery to the solenoid can cause a spark, or explode the battery.
So, the ignition switch, battery, starter, starter solenoid, a fuse, a neutral switch, brake switch, or wiring can be the cause of a starter not engaging.
Jun 01, 2014 | 2000 Ford Taurus
When i turn the key it just makes a click sound and nothing happens
If the battery is charged and the cables are clean, you are probably hearing the starter solenoid on the starter trying to engage.
If the starter can not be jumped directly, I would agree the starter is faulty.
Jun 29, 2012 | 1990 Nissan 300ZX
My 1990 Buick Lesabre will not start, I turn the key and it makes no noise at all, doesnt even try to turn over; All the lights turn on, radio plays, ect so I dont think its the battery. Any ideas?
Well, sometimes the lights, the radio, and other accessories will work, but the battery is not strong enough to operate the solenoid. May require charging to get it up to over 12 to 12.6 volts.
However, if the battery is good, and the connections are clean and tight, then I would say the starter has gone bad. The solenoid's plunger is not engaging with the flywheel, and the solenoid is not connecting the circuit that needs to be connected in order for the starter to get full current to its windings and turn the flywheel.
I think it may need a starter, then.
Oct 15, 2010 | 1990 Buick LeSabre
I think my starter solenoid is bad. When I try to start my truck it will turn over and then start clicking?
I think your battery is the more likely the problem. If the solenoid did not engage you would hear a high pitch whine with no click. The clicking is the solenoid trying to engage the starter gear but it only initially engages until the battery current drops causing it to oscillate. Turn on your dome light and see if it dims when you try to start it. If it does try to charge or jump the battery.
Jul 12, 2010 | 2004 Ford F150
Freelander unable to start at turn of key,
Does the starting solenoid engages? This is would sound like a deep clunk on your starter. When the solenoid engages it close the contact that energize the starter motor, but a worn contact on the solenoid would result in it engaging but not having enough current to turn the engine resulting in a clunking noise when you try to start.
The starter solenoid gets its 12 volt from a relay. This is referred to as the starter relay. If you try to crank, and you hear only a click but the starter do not turn, then the contacts on the relay maybe worn.
To sum it up, if you hear a loud clunk when it dont crank, its the starter solenoid. If you hear just a click but no crank, it could be the starter relay.
Aug 06, 2009 | 2002 Land Rover Freelander
1990 toyota camry won't start
Usually if you hear the starter solenoid click but the starter doesn't crank, its the starter. And since it was after a trip that is usually when starters are bad when they get hot.
Apr 25, 2009 | 1990 Toyota Camry
1990 300zx solenoid/starter relay
I would go for the starter motor personally first, as thats the part that cranks the engine over :)
that gets power, then it starts turning the flywheel, the starter motor also keeps the engine running inbetween the engines power strokes while its running.
Go for the starter relay & the starter motor :)
Thanks.
Apr 10, 2009 | 1990 Nissan 300ZX
Boating Logo
64 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
