Question about Whirlpool GEW9200L Electric Dryer
Where is my heating element located?
Where is my heating element located for my duet model gew9200?
  • 38 Answers
Remove the access cover in the rear, and it will be right there in front.
Posted on Jul 26, 2009
Duet. Where is the heating element located?
Its inside the case.
There is a how-to video on www.youtube.com. Try this video.
YouTube
Jun 10, 2015 | Whirlpool GEW9200L Electric Dryer
Error code 5H whirlpool front load washer, what does that mean.
Water temperature sensor control error:
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Jan 11, 2015 | Whirlpool Duet 3.8 cu. ft. Front Load...
How to fix Whirlpool duet dryer runs but does not heat?
The element is broken, you can pick up a replacement from any wholesaler of plumbing/electrical/appliance parts. Otherwise, there could also be an in-line fuse. if you look up your appliance on the internet ( a silver sticker on the lip or groove around the perimeter of the door has the serial number and model number) you can search the exact model number and find the manual, and then see if an in-line fuse exists. Otherwise, replace the heating element
Graham
Aug 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
GEW9200 electric dryer turns fine but won't heat up. I tested the thermal fuse, thermostat, heating coil and they are fine. What am I missing?
If you have 240 VAC to the dryer, the control likely has a faulty relay for the heater. Provided all the thermal fuses (especially the one on the side of the element can) are good and the voltage supply is good, the control will likely need to be replaced and is available below.
Control
Nov 24, 2013 | Kenmore Elite HE4 Electric Dryer
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer model # GEW9200 runs fine except will not heat up
It appears your Thermal Limit Fuse has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 02, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Whirlpool GEW9200L Electric Dryer Logo
214 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
