Question about Metrologic Instruments Voyager MS9520 Handheld
Default barcodes for the metrologic ms9590
I need the default barcodes for the metrologic ms9590 handheld scanner
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
SOURCE: DS6708 symbol scanner freezes keyboard
Have you tried taking the battery out of the scanner and then reinserting it? THis should reset the scanner to some degree.
It really depends which barcodes you scanned in the manual.
Your best chance seems to be a reset to the original settings, for which you may need to look at the manual.
Posted on Mar 18, 2008
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
Posted on Jul 08, 2010
SOURCE: i scan barcode into notepad ....computer goes haywire
heare are the manual but i search a manual whear i can enable the code 93, has any a idea?http://www.barcodemuseum.com/Datalogic/Manuals/dlc6000_820000512.pdf
Posted on Jan 21, 2011
What kind of cables do I need? my friend says that they are doggles - or something like that
RS232 Barcode Scanner Cable
Handheld scanner cable
Connector: DB9, DB15, RJ45
Cable: PU, PVC, 26AWG, 28AWG...
Application: Computer POS system, Scanner 0R Metrologic Honeywell barcode scanner MS9540 MS5145 USB Cable ???4 Similar from this Supplier Straight USB Cable with chip for Honeywell Metrologic MS5145, MS9540, MS9590, ETC....
May 04, 2011 | Computers & Internet
We can not get the scanner to reset to the factory defaults.
I am not sure if you try this yet,
If you scan the bar code located on page 14 from the manual (link below) it should reset the scanner back to factory default
http://www.barcode-uk.com/images/downloads/Metrologic%20MS1690%20Scanner%20CernInst.pdf
I hope this helps and best of luck!!
RM
Mar 10, 2011 | Metrologic Instruments Metrologic MS1690...
The cursor is not returning to the barcode box after someone scans their card.
By default, the scanner includes an enter at the end of the data, which can be changed by the control character that requires your application.
Regards.
Roberto Martinez
Jul 08, 2009 | Metrologic Instruments MS9540 Voyager CG...
Replaced battery - do I need to re-boot?
No you have to configure blutooth Adress, it's located on the bottem side of the scaner , scan that barcode and try to read, if it fall, get the user configuration gueid and enabel KBW OR USB ( first Chek Your communication method) if it's KBW trun to page 56 and scan Load keyboard Wedge Defaults , if it's usb trun to page 68 and scan enabel usb interface. if agein fall, scan the recall deafult and do the above steps.
mevan
MARC
Aug 04, 2008 | Metrologic Instruments Voyager BT MS9535...
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Aug 15, 2007 | Metrologic Instruments MS5145 Handheld
Metrologic Instruments Voyager MS9520 Handheld Logo
521 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
