Flashing F-05on hotpoint WT741 washing machine not spinning on any programme
  • 28 Answers
F05 mean blocked pump. Water level not reached empty.
Posted on Jul 27, 2009
I have a hotpoint wt741 washing machine and came up error f-05 I cleaned the filter out no joy. Then drained and put washing on fast spin which it did then pumped the washer full of water again help?
YOU COULD TRY CHANGING THE PRESSURE SWITCH.THIS IS A ROUND PLASTIC ITEM WITH A PLASTIC PIPE RUNNING OUT OF THE BOTTOM OF IT.EASILY ACCESSIBLE BY REMOVING THE LID
May 05, 2013 | Washing Machines
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Locate and remove large black hose fastened to drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
WT741 won't spin sticks on 1 min
there is a good chance is locking out on suds
try doing one load with no soap
then dont use anymore than a tablspoon
of any type of sopa
Oct 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
Hi.
F05 meqans that pressure switch is jammed.
You will neeed to call an engineer.
Jun 12, 2008 | Hotpoint WMA35 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
