I need schematic for 62-12 and tube layout.I purchased the radio at estate auction and 4 tubes are missing,also missing is the spkr.Don't know what else i may need! Thanks: James
  • 4 more comments
  • jamesg4348 Jul 26, 2009
    The radio is an Airline Pentode Superhetrodyne #62-12 made around 1931/1932.
    Manufactured by Montgomery Wards.
    radio has 8 tubes
    Airline "GRENADIER" Radio #62-12 Pentode Superhetrodyne Console Radio -Manufactured around 1931-1932.The radio has 8 tubes and 4 are missing along with missing spkr. in mine.
    I purchased the radio at estate auction and would like to repair it.I need tube layout and schematic. Thanks: James
    Schematic & tube layout needed
    I did not rate anything! Don't understand!
  • jamesg4348 Jul 28, 2009
    What I need is the tube layout or a schematic for Airline 62-12.Year 1931 ??
  • jamesg4348 Jul 29, 2009
    The radio was manufactured in 1931 and Riders Volume 2 - Mont Ward 2-4 &2-5 says I need to use #1238 and 1838 for the "Grenadier' Model 62-12.I need tube Layout and Schematic Diagram!
    Thanks: James
    President:
  • 1,734 Answers
Posted on Jul 29, 2009
  • 11,896 Answers
You can probably find it at retrevo.com
  • 1,555 Answers
Is this sony home theatre. Kindly let me know the correct brand and model number.
Posted on Jul 26, 2009
  • 4 more comments
  • Aruna Singh
    Aruna Singh Jul 26, 2009
    Kindly download this pdf meanwhile I'll trace the owner for your.
    www.pmillett.com/Books/intro_eddy_aero.pdf
  • Aruna Singh
    can you kindly let me know plz is this the Service book you were looking for.
  • Aruna Singh
    I do understand this is subordinate of VUC 201A and later ARC 610.
  • Aruna Singh
    I've worked for 5 years for communication Base Repair Depot for Air Force at Air Borne Radio Equipments Flt. You can't get everything within seconds. It obviously takes a bit of time.
  • Aruna Singh
    Anyways my further efforts won't be fruitful as you have already rated me. Thanks.
  • Aruna Singh
    Sir,
    You have rated me somewhat helpful and from now on I can just comment upon anything. I'm not your troubleshooter. He will be the next expert who would solve your problem even I'm in delima why didn't any expert approached you yet.
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
How do i fix a cb radio tube type has no receive
you have to have a vtvm a schematic of the radio and a replacement tube if necessary .With these tube types be very careful not to touch anything you shouldn't because you could get a terminal shock. with the schematic check the voltage spec and make sure the tube is actually working properly ,then check the socket to make sure that the correct voltage is getting to it Make sure you don't have any static because it will short out the radio.
Mar 24, 2015 | Radio Communications
There's a pinhole leak on a valve or a metal connector and I'm losing coolant. I don't know what the part is called. It's located in the middle behind the fan. It looks like a "t"...
This is a coolant tube that goes to the top of the water pump, it is called the upper water pump bypass tube, you will also need to purchase the rubber o-ring
When replacing, make sure you are doing a coolant flush, as old cooland will cause this type of corrosion and failure
good luck
Jay
Jun 24, 2011 | Ford Ranger Cars & Trucks
My mother purchased this TV and was told all it needs is a picture tube...where can i find a replacement tube(if that's what it takes)...
As far as I know flat panels don't use picture tubes. It may need a new screen or a new panel. Have you tried plugging it in and testing it?
May 04, 2011 | Televison & Video
I own an RCA A-20 radio circa 1940? I bought it at an estate auction several years ago. the glass tubes 'light up" but no sound. Is this worth repairing and is it something I can do myself?
Your problem could be due to a "bad" tube or any one of a long list of other things. Typical repairs would likely run at least $75, and you could spend that much replacing tubes. Unless the set has high sentimental value it's probably not worth fixing. I don't show any "A" series RCA sets, so I can't validate the set's age or value.
Oct 02, 2009 | Audio Players & Recorders
Need fuse size
AGC-7 is a 1-1/4" X 1/4" glass tube fuse with metal ends rated for fast blowing at 7 amps. You should be able to get this fuse practically anywhere. Including radio shack.
Apr 26, 2009 | Audio Players & Recorders
I have a rca picture tube tester and i would like to know how to make a scoket to test the newer pictures tubes used to day.
You will need to get the schematics to the tube that you have a socket for and then identify which are the heather, cathode and etc and then you can use micro clips that you can color code, and then just do the pin outs for the various tubes your testing. I used that same proceedure with my B&K tube rejuvinator and it worked like a charm i bought the micro test leads from radio shack and just cut the old type socket of which I knew the pin outs on and then its easy to pin out the newer tubes
Jul 11, 2008 | Televison & Video
95 people viewed this question
 Grubhead
Grubhead
