Question about Samsung Washing Machines
Tried to solve the error 5E of the Samsung washing machine and all remedies in the manual did not work
Tried to solve the error 5E of the Samsung washing machine wf8604nhwg and all remedies in the manual did not work. Who knows what to do? Should I check the water pump? If yes, how to do it? Thanks in advance!
    Sergeant:
  • 231 Answers
If there is water still in the drum what you need to do is at the bottom of your washing machine is where the filter is based open the round door and you should see a screw know and a drain funnel , if you have water in the drum pull out the drain funnel and let the water out using a bowl or dish take off the filter plug , using a good torch look into the filter hole and you will see a little fan, clean all around it long nose pliers job done turn power off first colin
Posted on Jun 14, 2017
Testimonial: "Hi Colin, Thanks for your support. I tried to clean the fan. It was already clean. Check a picture https://drive.google.com/open?id=0B9pqy_9bFoKKcjRVMzBRUi1nX1E. I have suspicions that the drain pump is not ok. When I do a washing cycle a program runs (i think) until draining is required. Then washing stops and timer runs and after some time 5e error appears. Do you know how I can check if the drain pump is working fine. Regards, Serg"
  • 3 more comments
  • Anonymous Jun 15, 2017
    "Hi Colin, Thanks for your support. I tried to clean the fan. It was already clean. Check a picture. I have suspicions that the drain pump is not ok. When I do a washing cycle a program runs (i think) until draining is required. Then washing stops and timer runs and after some time 5e error appears. Do you know how I can check if the drain pump is working fine. Regards, Serg"
  • Colin Evans
    Colin Evans Jun 15, 2017
    Lay the machine down on one side and unscrew the pump , take out the pump and you will need a multimetre. Check the resistance which should be about 162 ish I've never had to renew one as thay always get blocked . Ps make sure you unplug the machine first and good luck,cost about £20 to £30 colin
  • Anonymous Jun 16, 2017
    Hey, Colin. thanks for a good luck.
    I Extracted the pump and checked the resistance it was 175 Ohm . I even connected a motor of the pump and noticed that it worked. However an o-ring of the pump was stretched out and I think it blocked the pump rotation. I want to buy a new o-ring and install it.
    Do you know which type and size should it be. Or it is standard O-ring for a drain pumps?
    Thanks!
    Regards.
    Serg
  • Anonymous Jun 18, 2017
    I found the issue. It was pump motor. When I connected it worked every other time. Looks like it was not enough power to move the motor rotor/shaft. I will buy another pump. Analogue Askoll costs around 15 euro.
  • Staf canon sevice
    Staf canon sevice Aug 30, 2017
    canonprintersdrivers.com
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
Sep 19, 2015 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
WASHING MACHINE SHOWING ERRORMESSAGE 5E
rw
Hello, and sorry to read about you 5E code issue.
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
If your hose shows no kink's you may have a clogged pump.
I have tried to help you. PLEASE rate/vote the response. we take the time to respond to you. take the time to rate. Thanks and good luck on your problem.
Dec 24, 2010 | Samsung WF306BHW High Efficiency Front...
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
I HAVE BOUGHT SAMSUNGWA80V3 TOP LOADING WASHING MACHINE. I AM GETTING ERROR 5E and WATER IS NOT DRAINED OUT.PLS ADVICE.
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Nov 09, 2010 | Samsung Washing Machines
Washing Machines Logo
4,462 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
