Is their a picture that can help me find the ac water drain for 2004 endeavor and hint to solve problem
  • 6,674 Answers
What is the problem ?
Posted on Jul 26, 2009
2008 Mitsubishi Endeavor. Blower motor no longer works. Right before completely dying. If I would turn left I heard water flowing and blower barely worked. Now no water noise or fan working. Help plz
2004 Mitsubishi Endeavor AC transistor blower fix - YouTube
? 8:02
www.youtube.com/watch?v=6g_xozxuziE
Mar 19, 2015 - Uploaded by Peter Zafra
How to fix a Mitsubishi endeavor ac blower that stopped working. ... 2008 Mitsubishi Lancer HVAC Blower Motor Install How To - Duration: 9:07.
Sep 10, 2015 | Mitsubishi Cars & Trucks
Wre is the ac drain plug on the 2004 endevour {mitsu}
Ac systems don't have drainplugs they have what's called a core and if u want to drain the system you should go to a ac shop and have them "evacuate " the system or you could face big fines for letting the contents in to the air good luck hope this helps
Jul 17, 2011 | 2004 Mitsubishi Endeavor
Water on floor on passenger side when a/c in use or heat is not antifreeze.
your condensor drain is cloged up go under passanger side of vehicle there should be a spot under there where the ac water condesation drains out clean the drain out
Dec 20, 2010 | 2004 Mitsubishi Endeavor
Mitsubishi Endeavor 2004. 1. the tail gate and the tail gate glass do not open 2. the AC drains into the driver flooring instead of draining outside to the ground. Why? And where is the output drain...
The door and the glass just needs some penetrating lubricant( WD 40 ), just a few squirt will do on hinges and locks!
The drainage hose would be under the passenger side( RiGHT FRONT SiDE) glove box, look down there, u will see a black hose from the center that houses ur A/C & heater housing! Lift up ur floor covering to see it clearly. check and clean the hose it might already been clogged by moss and dirt or dislocated thru the drain holes on the flooring! Hope that helps out! Taah!
Nov 18, 2010 | 2004 Mitsubishi Endeavor
My 2004 endeavor a/c is draining in the vehicle on the drivers side floor board and i took that side up and was water galore. it looks like it is draining from that black drain from the center but does not...
Same thing happened with my 2004 endeavor. There are 2 fixes (as I understand) for this...the first is to get the drain hose blown out. It can get clogged with gunk, then the resevoir fills up with condensation water and overflow.
The other fix is much more involved and expensive. As I understand it from some research I have done, the drainage hole in the resevoir gets clogged with debris that has made its way down from the grill on the hood just in front of the windshield. There is no filter there (Mitsubishi now has one available), so leaf crud, dust and dirt can get drawn into the resevoir and clog it up.
The permanent fix is to pull the AC to get to the resevoir, pull and clean the resevoir, reinstall everything, then put the filter under the grate.
BTW, when my mechanic blew out my hose and was draining the car, he said there is a hollow space underneath the floorboard and it was holding about 5 gallons of water.
So far, running the AC in southern humidity, it has not backed up in about 4 months. I may have to have it blown out again next spring to avoid the water problem again (this was the second time I had to have the condenser drain line blown out).
Hope this helped.
Sep 07, 2010 | 2004 Mitsubishi Endeavor
AC drained into blower motor...replaced moter and now wont work
Did you check the blower motor before installation?Check for a blown fuse,and a bad relay,also check the blower motor resister.I hope this was some help.
Oct 05, 2009 | 2004 Mitsubishi Endeavor
2004 Endeavor AC condensation gathering in huge puddles on drivers side...can't find obvious point of entry...have pulled back carpet but still no clue
Water puddling on the driver side (ONLY) of Endeavors is evidence of the drain tube foam seal failing. This is very common on Endeavors, and will be more evident on humid days, rainy days, especially with extended driving.
The drain tube for the AC system that extends through the firewall has a small foam ring that seals moisture from running back into the car after it goes out the tube (think of pouring water out of a glass, how some always runs down the side).
High humidity days will cause more condensate than normal and amplify your symptom. Rain will also make it worse, as road water will spit up to the drain hole, as well as normally enter the box through your fresh air vent, creating more water to drain. Driving speed also help force the water past the seal.
The only correct repair is to remove the evaporator box (requires dash removal) and either replace the seal with a new one, or as I prefer replace it with a butyl rubber type substitute that will not degrade like the foam.
You can pack butyl rubber or similar (think windshield packing) around the seal flange on the inside, but it is not an ideal repair.
Sep 06, 2009 | 2004 Mitsubishi Endeavor
2005 Mitsubishi Endeavor Air Conditioning Drain Leak
Water dripping on the passenger side is usually accompanied by rushing water noise during sharp turns. This is extremely common on Endeavors, and is caused by a blockage in the drain of the AC system. It can be caused by leaves/debris or insulation foam that has come loose. There is a bulletin to remove the foam and any leaves/debris under warranty (5y/60k) and install a cabin filter to prevent recurrence.
Jul 27, 2009 | 2004 Mitsubishi Endeavor
I HAVE AN ENDEAVOR 2004 AND IS LEAKING IN PASSENGER SIDE
refer to this post for a solution
http://www.fixya.com/cars/t2592290-air_conditioner_drain_plugged
Jul 26, 2009 | 2004 Mitsubishi Endeavor
2004 Mitsubishi Endeavor ac condensation drain is clogged.
It should be under your hood, on the firewall. Should be a short black hose there somewhere.
May 17, 2009 | 2004 Mitsubishi Endeavor
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
