Question about Brother IntelliFAX 4100 Laser Fax
Dark toner streaks
We have done the cleaning/maintenance suggested in the manual but we continue to get dark lines and smudges down the center of incoming faxes. any suggestions???? thanks!
  • Brother Master
  • 1,113 Answers
Can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
Posted on Nov 22, 2007
My HP LaserJet 1300 printer smudges the entire document and the toner is very faint. The cartridge has toner in it.
It means your machine needs cleaning. You can purchase cleaning sheets from the office supply store, and insert it like a regular document, hit print, and the dirt comes off.
Dec 21, 2012 | HP LaserJet 1300 Printer
How to clean a hp laserjet 2200d
Remove left,right,back and top covers, remove fuser assembly mounted at back side,use blower to blow the deposited toner in corners of the printer, once feels its cleaned clean fuser with cotton cloth fix all parts & covers back, check for the quality, My suggestion at least minimum knoledge reuired to do this activity, breakage of plastic/trays chancess are high due to old age.
Jan 30, 2012 | HP LaserJet 2200D Printer
When you print anything, especially pictures, there are black smudges on the paper. They look like roller marks. I performed all the regular maintenance but it continues. If you touch these lines, they...
You may have a bad fuser. The fuser is the part of the printer that burn/melt the toner/ink onto the pager. Check the fuser roller and make sure it lock down and clean.
Jan 02, 2011 | Office Equipment & Supplies
Dark smudge down center of sheets
You could have a faulty cartridge, try replacing the cartridge. If the problem is still there you may need to have a cleaning done on your printer.
Jun 08, 2010 | Brother MFC-9420CN All-In-One Laser...
Whenever our Kyocera Fs-720 printer prints it leaves dark splotchy smudges all the way down the page, any suggestions?
Your printer probably is due for a maintenance clean, which can be done by a certified printer technician.
May 28, 2010 | Kyocera FS-720 Laser Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Vertical streak near left edge of printouts....only affects black portion of print image
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Apr 11, 2007 | Ricoh CL3000E Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
325 people viewed this question
James Cagle
James Cagle
Jim Keysor
