Question about Apple iPhone Smartphone
I brought an iphone but the screen works say once every month
I need someone to tell me how to fix my problem because i cant use my phone untill the touch screen works properly if u can tell me how to get it working i would be very greatful thank you
SOURCE: iphone touch screen
Thanks!!!!!! I just tried resetting the phone and it worked. It turned on and everything was back to normal. Why did that happen?
Posted on Jan 01, 2008
ipodslinger
  • 688 Answers
SOURCE: half white screen
The iphone screen is divided in half and has a connection for each.
Have you had the phone apart recently? if so you may have a loose connection on the LCD
If not you LCD could have just gone bad.
Is your phone under warranty?
If you have Apple Care, call the local apple store and take the phone to them. They will probably give you a replacement under warranty.
If it is not under warranty, find a local cell phone tech and have the LCD replaced or replace it yourself.
The 3G is fairly easy to work on if your really really careful getting the Front Glass off.
if this post helps you please leave a vote in fixya
Posted on May 24, 2009
susniktucker
SOURCE: IPHONE TOP HALF OF THE SCREEN NOT WORKING
im having same problem . please if you find out anything let me know!!! susniktucker@yahoo.com
Posted on Jul 24, 2009
  • 8 Answers
SOURCE: iphone touch screen problem
Try pushing the power button and the home button at once and wait for it to restart, that should fixed the problem...
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: my iphone 3gs touch screen is not working, i cant
just reboot it hold the power and home button down until u see the apple logo and then just release them
Posted on Apr 29, 2010
My iphone screen is completly black i've tried holding the home and the off button down at the same time and its still not working wtf . i really need help !!
Hi, this happened to me once and I researched a fix by looking for 'iPhone black screen of death'
Here's one of the current articles that comes up under that search:
1) If an application (such as Safari) is frozen, just press and hold the iPhone's home button for about 5 seconds, or until the home screen shows up. (This didn't work for my iPhone so we had to perform a soft reset).
2) To perform a soft reset, press and hold the iPhone's Sleep/Wake button and the Home button for several seconds, or until you see the apple logo on the screen. (This action did reset my iPhone and I was very happy at this point). The guys that helped me said that continually performing soft resets can cause problems however.
3) Hard resets are not recommended, but are required when a soft reset won't do the trick. The Apple Geniuses wouldn't tell me the key combo to perform a hard reset because it restores the iPhone to a state that's unusable. Users risk losing data and you must synch your iPhone with iTunes to make it function after a hard reset.
Also, if you are not turning off apps after use they could be overloading things and might cause it to happen again. to turn off apps do a double tap on the 'Home' button, and all your open apps will be listed along the bottom of the screen. press on one icon and hold until the icons start to wobble and have the X in the top right corner click on these to turn them off. Its also good practice to do this several times a day if you use a lot of apps because having ghem open eats up your battery power.
Apr 17, 2013 | Apple iPhone Smartphone
I had an iphone,a relative gave it to me from US..i deleted all the media and data in it,now i cant open it.it was displayed on the screen a figure of an apple with a working bar..is my iphone damaged...
You need to put your iPhone into recovery mode. To do this:
Press and hold both the "power" and "home" buttons until the phone turns off.
Once the phone is off and the screen goes black, release the power button while continuing to hold down the home button.
Hold the home button for approximately 10-15 seconds and you should see the screen come on with an image directing you to plug your iPhone into your computer.
Your phone is now in recovery mode. iTunes will detect the phone's status and reformat it so that it will once again work properly.
Jun 01, 2011 | Apple iPhone (16 GB) Smartphone
I have an iphone 3G and it was thrown to the ground where the screen has smashed. The scrren is white but the phone rings
that means that the phone itself aka internal hardware is working just fine(hopefully since we cant actually know right now) but you NEED to replace that screen. Once you do everything else should be back to normal, or we will be able to tell what is working and what else is broken.
May 03, 2011 | Apple iPhone 3G
My iPhone is stuck on the white screen but i cant really use it..i tried to restore it on itunes but i cant since it has a passcode but i cant type it in because the screens white and i cant see the...
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jan 27, 2011 | Apple iPhone Smartphone
My iphone screen is cracked and my touch slide button wont work but i can still can except call but i cant slide it to unlock it is there anyway to fix it
my phone is a IPhone 3gs and i cracked the screen a couple of months ago and a couple of days ago my screen started to act really slow and it wouldnt work on some parts and now today my screen wont work nor respond at all. PLEASE HELP ME I REALLY NEED MY PHONE ...!!!!!
Jun 16, 2010 | Apple iPhone Smartphone
Hello i brought a iphone on ebay it looks like someone tried to jailbreak it but it did not work . the phone will not into dfu mode or recovery mode i held power and home butten and nothing works how or...
turn your iphone to dfu mode.
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Jun 03, 2010 | Apple iPhone Smartphone
Hi my i phone screen has stopped working completly its 8 months old would this be covered under warrany - the screen has a crack in it but not connected at all its been like this for ages., i cant turn the...
Sorry but your screen needs replacement. Take it to the apple store and see if they'll give you a replacement. Your within the warranty period, but it may be considered physical damage. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself. The part is on Ebay.
Nov 02, 2009 | Apple iPhone Smartphone
My iphone wont respond to touch i cant use it
try hard reset (hold down the power button and the central button until you see Apple logo on screen). If this wont help then use RESTORE.
Aug 25, 2009 | Apple iPhone 3G Black Smartphone
My IPhone clone screen' has stopped working
ur digitizer is broken...if u brought it from a store u kan go bak 2 dat store and git it fixed 4 like $10 to $15
Aug 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Iphone touch screen problem
Aug 03, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
29 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
