Question about HP Pavillion DV6227 Notebook
HP PAVILLION DV6227 WONT TURN ON
COMPUTER WAS ON BUT NOT IN USE.I WENT OUTSIDE AND WHEN I CAME BACK IN, POWER WAS OFF. IT WAS PLUGGED INTO THE A/C ADAPTER AT THE TIME, SO BATTERY DID NOT DIE... NOW, IT WONT HOLD POWER LONG ENOUGH TO BOOT UP. WHEN I PUSH THE POWER BUTTON :
1) I CAN HEAR,WHAT SOUNDS LIKE FAN COME ON FOR APROX 2 SEC'S
2) THE BLUE LED POWER & KEYBOARD AREA LIGHTS COME ON, THEN EVERYTHING IMMEDIATELY TURNS OFF.
3) MY SCREEN NEVER SHOWS ANY SIGN OF POWER
..... ALSO, WHEN A/C ADAPTER IS PLUGGED IN, I CAN SEE THE BLUE LIGHT ON AT THE CONNECTOR SITE AND BLUE LIGHT UNDER THE LIGHTENING BOLT SYMBOL LIGHTS UP, BUT ONLY STAYS LIT FOR APROX 2 MINUTES........
WHAT COULD BE WRONG? AND ANY IDEA HOW EXPENSIVE IT IS TO FIX?? THANKS IN ADVANCE FOR ANY HELP OR INFO YOU CAN GIVE ME
    Problem Solver:
  • 58 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
33
Posted on Jul 26, 2009
One of my ac's light is blinking and wont turn on. Is not the control batteries, what could it be?
Laptop Won't Turn on, Blinking lights - HP Support Forum ...
h30434.www3.hp.com > Laptop & Notebook > Boot
Solved: Hello My laptop is an HP pavillion dv6z-1100, its running a 64 bit version of windows 7 ... Message 1 of 38 (164,169 Views) ... Upon attempting to turn it back on (while being plugged into the ac adapter) the computer would power up, ...
Air conditioner light blinks - Discussion on Topix
www.topix.com > Chevrolet Malibu
Jul 11, 2006 - my 2001 Malibu has this problem, blinking A/C light. ... On the control panel for the air conditioner, the ac button(the one with the little green light) blinks on ... The ac will turn itself back to outside air after it has been running on ... 2002 A\C Blinking
May 14, 2007
2003 Toyota Camry A/C button flashing
Apr 10, 2007
More results from www.topix.com
Dec 25, 2015 | Computers & Internet
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
The charging indicator light no longer comes on when the laptop is plugged in. Just replaced the battery. Also tried a different power cord.
Possibly a failed or damaged charging port (does it feel loose)? After that, charger may not be chucking out the voltage (19.5 volts)? Test with multimeter set to DV volts, with one probe on the inside of the plug ant the other on the outside.
Does the charger LED light blink when connected (sign that power is not making a circuit)
If the above fail to work, then the problem is with the connector on the mobo, this may just be a Charger port needing replacing (wired or soldered version), or the charging circuit of the motherboard gone
Feb 10, 2011 | HP Pavillion DV6227 Notebook
Hp pavillion dv6227 pc notebook black screen during start up?
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 21, 2010 | HP Pavillion DV6227 Notebook
My dv6700 will start up and run for awhile then just shut off even when plugged in,could a defective battery cause this?
It sounds like an overheating problem. Try using some compressed air to blow out any debris from the ventilation slots along the edge and bottom where the fan is. Be sure the fan is in deed working also.
Aug 12, 2010 | HP Pavillion DV6227 Notebook
What is the driver of hp pavillion dv6000 web cam?
Welcome to FixYA
Dear User,
Your Webcam Driver is Here....Download from Here and Install it Properly....
You will be Solved...
If this Helps you-Dont for get to RATE me....Thanks for Contacting FixYa....
Jul 03, 2010 | HP Pavillion DV6227 Notebook
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
Apr 09, 2010 | HP Pavillion DV6227 Notebook
MY HP PAVILLION 6262 LAPTOP WONT POWER UP, LIGHTS COME ON FAN STARTS, BLACK SCREEN. GOES OF AND TRIES TO START AGAIN AFTER A FEW SECONDS. HARD DRIVE, MEMORY AND SCREEN ALL CHECK OUT OK. IT ALL STARTED WHEN...
see if you can boot into safe mode as the pc starts tap F8 - should be presented with a menu - choose "safe mode" from the menu if that works, then try a system restore to before the problem started start>programs>accessories>system tools>system restore choose a date before the problem started
reboot
Mar 24, 2010 | HP Pavillion DV6227 Notebook
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Does not boot up
ovewr heating greese on cpu no good power c hips getting to hot dusty inside clean it out get labtop cooler pad
Jan 22, 2008 | HP Pavillion DV6227 Notebook
HP Pavillion DV6227 Notebook Logo
395 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
