Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Sucks up hair and dust but it all collects on the brushes
Lately when I vacuum it cleans the tiled floors well but it does not take it into the container. It all collects around the brushes and so I use the hose to **** it up from the brushes. What is wrong and what should I do?
Thank you
Ilana
  • 38 Answers
It has a obstruction somewhere in the plastic pipe. You are going to have to get your hands dirty and tear it apart. Dont be affraid, its easier than it looks, just take it apart slowly and take pictures as you go. When you get the bott exposed you will need to stick a wire in there and dig out the obstruction. Good luck
Posted on Jul 26, 2009
Tip
When I called they indicated that the brush roller can be removed with a...
Keep the brushes cleaned regularly. I used a pick to pull out the hair and dust bunnies. It took a while, but will be easier if done regularly.
I tend to want to wash everything with soap and water. They recommended not using water.
on Sep 23, 2013 | Dyson DC35 Multi Floor Digital Slim...
Dyson dc59 troubleshooting
Have you checked the rotary brush at the front. Although IO dont have the same model of dyson I need to clean out the dog hairs that get wrapped around the main rotary brush which is easily got to by turning the catches with a coin under the cleaning head. They should have a little arrow or padlock symbol showing which way to turn them
Aug 17, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
Hello this vacuum cleaner has great suction through the hose but not in the main part, it will not pick up i have cheked to see if it is blocked but does not appear to be. any ideas?
If it sucks through the hose it must have a blockage in the pipe or at the head. Remove head and check for hairs and thread which often cause dust to collect there in a knot. Clean the brushes. You should be able to see daylight at the end of the pipe. Put your fingers in the part of the head that goes onto the pipe and feel for a blockage. Or push a thin wire through.
Feb 13, 2011 | Bissell Upright Vacuum - The Pet Hair...
Notices some problem with suction on my Karcher RC3000. Much of the dust remains on the brush and doesn't get sucked in. Service couldn't advise anything. Any ideas?
The air passages through the machine may be plugged, or the impeller (fan) on the motor is slipping on the shaft so that no vacuum is produced. Remove the brush assembly to check the air passage behind it and inspect the brush bearings for collections of thread, string, and hair. Also, inspect the debris collection area for air passage blocking. If there is a filter where the air discharges that might be plugged. Hope some of this helps!
Oct 10, 2010 | Karcher RC3000 Bagless Robotic Vacuum
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Brushes on my roomba don't seem to be spinning.
Try running your roomba with the dust bin removed to see if the brushes turn. Take the brushes out and make sure they're clean. You may need to replace the brushes if they're worn. Failing that, you can find instructions on how to take your roomba apart. Take out the brush assembly and open the screws on the side of it to expose the gears that drive the brushes. There will probably be a lot of gunk in there jamming them up. You might need to check the motor too.
Sep 24, 2009 | Roomba Robotic Floor Bagless Vacuum
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction
Roomba does much of its cleaning by the brush and roller on the bottom, but an important part is the little fan at the back of the debris bin which provides 100% of the 'suction.'
First, take off the vent cover on the back of the debris compartment and start Roomba on a mission. You will see the little turbine spin (if it's working) and probably a little dust cloud will come out.
It may not be working at best efficiency, however, because dirt gets sucked into the housing and blocks much of the air flow. Now that you know what the fan/turbine looks like (it's quite small, only the size of two stacked silver dollars), peer down into the larger opening of the debris bin and view the turbine from the other side. Chances are there's some crud stuck down there which is impeding air flow. (There's a hollow part of the turbine where the air is sucked into before being expelled out the back, that's probably filled with pet hair/dust/etc.) Clean that out using a long knife, chopsticks, or anything else that can reach down in there. Bang the dust bin down (lightly) to dislodge any more hair that's up there and continue cleaning until it's all gone.
I've had 3 Roomba's and they all get hair stuck up there. I only have to do this once a year or so (multi-cat and dog household here!) but it makes all the difference in the world.
May 01, 2008 | Roomba Robotic Floor Bagless Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
57 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
