Hi I have a Hotpoint Ultima 6kg WMA 76 washing machine - had for 6/7yrs. It has just started leaking water from the drawer when it changes from the wash cycle to the spin cycle...have given the drawer and inside drawer a very very good clean with bleach incase clogged up but it is still leaking...thanks for reading...Any ideas???
  • Washing Mach... Master
  • 3,463 Answers
You need to check the pump filter, and clean same.
Remove lower rear cover, locate and remove large black hose, remove and clean filter inside hose.
Please rate my solutioon.
Thanks.
Posted on Jul 26, 2009
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
Water comeing from drower
Check for water leak with drawer open while washer is operating from beginning of cycle. Your problem could be attributed to one of the following:
* water valve
* water inlet hose
* rubber door seal
Contact an appliance service company.
Feb 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Water leaking from soap drawer all over the floor during rinse cycle (I think)
probably find a blockage at back of drawer, check the small pipe in the drawer, and unblock this should solve problem
Dec 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint aquarius 6kg washing machine, i need to cancel a progeamme and drain the washing machine as their is a sleeve caught in the door and water is coming out but don't know how to please...
hiya
if the model starts with wm then you should set the timer knob just before a spin setting and it will empty out.
if the model starts with wma,few or wf then you will have to hold in the start button as this will cancel the current cycle and should start to drain.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Hotpoint Washing Machines
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Leaking water
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
Oct 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
222 people viewed this question
Top Washing Machines Experts
