Question about SanDisk Sansa Fuze MP3 Player
Charging problem when we put our ipod on charging it is not working
  • 153 Answers
Well please explain what is not working i pod is not getting current or there is any problem with ur charger if the problem is with ur ipod there must b some problem with power supply and plz check the chjarger to confirm and if there is still the problem please let me know will try to help u in every way thank u.
Posted on Jul 26, 2009
  • 54 Answers
Friend Some MP4 Players have some safty menus like Auto Power Saver
and Also like Data Protector
I think U R MP4 Player also having same kind of Feature so dont worry
  • samadhan  chavhan
    samadhan chavhan Jun 06, 2010
    Change ur charger & check then go for ipod check if charger is not working then u know what to do & if ipod is not working so give it to service center becouse it might be a power IC problem
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
I don't know how to make the Ipod go dark after it is on the clok
first set then alarm. then set your ipod lock time to 1 min. you can fine it on your ipod setting. hope i help you.
Jan 11, 2010 | Digital Products International Clok Smooth...
Damage by water, problem of charging and unlock
Sorry, water ingress is mostly fatal. Even if it works initially it will eventually fail as the water will cause short circuits on the components. However, try this to put off the inevitable. Do not turn it on. Get some silica gel from your chemist. Put this in a plastic bag and put the iPod in with the silica gel. Leave it sealed for at least a day. Remove the iPod and dry the silica gel in the oven and repeat the process several times. Do not heat the iPod. Good luck.
Dec 01, 2009 | Apple iPod touch
My ipod touch will not turrn on or reboot whats wrong?
Checklist to see if your iPod needs a reboot:
. Your iPod is charged.
*If not, you might have to plug in your iPod, and make sure the computer can't go to sleep while it's charging. The iPod won't charge if the iPod is locked, so no orange.
Charging your iPod problem solution, that also works.
* Your iPod might need to completely drain in battery source before you can charge it. If that's the case, leave the iPod unplugged for 24 hours before trying to charge it. That will make sure the power is drained and your iPod is ready to be charged.
2. Your iPod is unlocked. Slide the button back and fourth a couple of times, just to make sure it's working.
3. And your iPod still has a black screen, frozen logo, or white screen.
Rebooting your iPod.
1. Run a cold boot (shut your computer down, then turn it back on) on your computer. * If your iPod crashed because of the software freezing, or the computer crashed.
2. Open your Apple Software.
3. Plug in your iPod. Make sure that you plug in your iPod into your computer, and that the plugs are secure. Your computer should detect your iPod, black screen or not.
4. Set down the iPod. Take your iPod and put it on a flat surface.
5. Press firmly. Take your fingers, and firmly press the middle button, and the menu button. It will read menu on the top button of the click wheel, and the center circle of your click wheel is what your looking for.
* Make sure your fingers are planted on the top of the center button, close to the menu button, and you are pressing it together.
6. Count to 8.
Now you should see an Apple logo pop up on your iPod screen.
Sometimes you need to try it a few times, to get it to work.
It should be synchronizing and happily you should be on your way.
*You also can reboot your iPod without it being plugged into the computer, I always do mine while it's plugged in.
you have to erease all the dta on mines and put the music and everything back on,
Sep 23, 2009 | Apple iPod touch
IPod Nano 4thGen won't charge on Emerson iP100
ipod of the 4th gen. only charges in USB mode and not in Fire wire mode(ilink1394).
models of 3th gen don't have this problem.
Mar 08, 2009 | Emerson iP100PK Portable Docking Station...
My ipod wont connect to the IDJ2
Is the ipod charged? I have had the same issue, because the mixer charges as it plays i have had to wait a few minutes and tryed again. Hope this helps I use a thirty gig as well as a nano for a back-up
Feb 16, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Ipod wont sync with media player
try to reset the ipodul download the new itunes and if does not work try to download a software called xilisoft ipod ipad iphone from torrent and you put what you want in your ipod with it
Aug 28, 2008 | Apple iPod classic MP3 Player
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
Problem with iLive IBCD3816DT
Maybe charge the Ipod and then once completely charged, put it back on.
Dec 26, 2007 | Apple iLive IBCD3816DT Portable 2.1...
SanDisk Sansa Fuze MP3 Player Logo
209 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
