Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
HT1000 repair What are the possible solutions to repair an HT1000 that sounds like it's being held up to the wind when transmitting?  Battery, shoulder mic & antenna test ok.  Receives ok.  Repair monitor says its transmitting up to specs.  Repair tech can't determine the issue.  Radio is at least 10yrs old & I'm told by other HT1000 user that this sound is common with older units.  Also aware of Motorola Repair Kit REX4465A - is it applicable to what I mention?
  • WSGSD Nov 25, 2007
    No noticeable corrosion/rust. Contacts seem okay. I've got 4 HT1000s with the same problem, so I'd kinda doubt they would all have bad contacts.
  • 123 Answers
Check the battery contacts for any dust or corrotion.
Posted on Nov 22, 2007
  • Ernesto  Garcia
    Ernesto Garcia Nov 26, 2007
    Definitly I need to study this case, in my experience I dont remember this issue, sorry for not give an accurate anwer.
Hi Ricky,
You need help programming your Motorola HT1000 to scan.
This is tricky, but I may have the solution you seek.
Join yahoo group Specific to your radio Make/Model, the team there will help you find the answer, plus you can download manuals, diagrams and other goodies (if available), for your radio, all this is free.
I hope your query has been satisfactorily answered.
Oct 12, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
How to change the squelch on mtx8000
You can always have a radio receive. To transmit require an FCC License, and you need authorization to "Talk" to Public Safety. There are large fines and possible jail time to talk on channels you are not authorized for, especially Public Safety. Sadly, your radio is programmed to monitor only when the button is held down. The frequencies in your area working are a lucky coincidence. Take it to an Authorized Motorola Dealer and pay to have it reprogrammed. Radio is not field programmable. Hold onto your wallet, they are expensive to have programmed. You should have bought a high end digital scanner.
Aug 29, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
New hand held Midland CB Model #75-785 that will not transmit
Try asking any onrt CB'ers if they can hear you at all.
Could be 2 things -
#1 - you are really too close.
#2 - you've blown the output stage of your rig by keying the mic without an aerial fitted.
- This is very common, and most repair centres are used to dealing with this.
If you are up to electronic repair, it's possible to DIY repair.
Could also be an antenna mismatch or fault.
Mar 01, 2010 | Midland 75-785 Handheld CB Radio
I need to get a manual for Ht1000 and ex500.
Unable to locate a PDF file for the EX500 or HT1000 online, however, here are the part numbers you can order by HKLN4118A for EX500 and 6881079C50 for HT1000.
Best regards.
Feb 10, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Bad transmission
Troubleshooting ideas:
1) Try the radio without the remote speaker mic (RSM) attached. Do you still have the same issue?
2) Check the RSM's mic area for dirt/debris or something covering the hole. It is usually in the lower corner of the grill area of the mic.
3) Try someone else's RSM on your radio and see if the problem is still there.
4) Check your battery. An old or defective battery will cause transmit issues. Try a known-good battery from another radio to see.
5) If all of the above are addressed and you still have an issue, you may be experiencing low transmit power, and your radio would need to be serviced.
Mar 22, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Ht1000 receivers
Just offhand it sounds like an intermittant solder joint on the circuit board. Just my thought,,, Mechanic
Nov 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
This unit is in need of repair.
Jul 15, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
read the radio on the computer and see if the TX is enabled.
Also the PA could be faulty
May 02, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
It sounds like the radio may be in service or programming mode. Try turning it off, remove the battery, and reconnect the battery. Let me know if that solves the problem or not.
Jan 05, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
300 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
