Question about Garden
Chainsaw starts and runs fine for a few minutes
Craftsman 18 inch chainsaw starts and runs fine for a few minutes then dies hard to restart close chock it will restart open chock and it will start and again die after a few minutes. any ideas
    Sergeant:
    Champion:
  • 246 Answers
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Posted on Jul 26, 2009
  • David Toney Aug 04, 2014
    alreadt tried sears recomended fuel and new carb.anything else to look at.thinking maybe the coil monule
Chainsaw won't start?
2 possibles
coil is getting hot and failing
do you have spark straight after it stops
is air filter clean
carby diaphragm or carby rebuild required
May 31, 2016 | Garden
I have the kit craftsman chainsaw 18 inch, with 42 ml engine. The problem is when you finally get it started, it dies when you give it gas. I need an answer please?
I see this problem a lot, so I just decided to research the problem. Yes, it is a known problem with chainsaws. Put down to fuel starvation for a number of reasons.
dirty/stale/contaminated gas
clogged fuel filter
clogged air filter
incorrect carb gas to air mixture
wood particles in carb jet
loose carb
http://www.bing.com/search?q=craftsman+chainsaw+dies+when+you+give+it+gas&qs=n&form=QBRE&pq=craftsman+chainsaw+dies+when+you+give+it+gas&sc=0-0&sp=-1&sk=&cvid=1987a3ed5bd649c2a6cb89f99f270d8b
Nov 10, 2015 | Craftsman Garden
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
CHAIN SAW QUITS RUNING AFTER WARM UP
remove the muffler and run it if it runs good without it open the muffler and clean of the screen inside
Jun 06, 2012 | Craftsman 18 Inch 2.6 Ci Chainsaw Tank...
Poulan pro 42cc starts when choked,take off choke runs almost 1 minute and dies.chock and restart same thing. will not stay running even when throttled.
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. If no help, remove the carburetor, disassemble and clean the interior with spray carburetor cleaner. Check the condition of the diaphragm in the lower chamber--it should be flexible with no holes or cracks. Also check the small needle valve that the diaphragm controls. Check the crankcase impulse passage behind the carburetor for gasket failure or other damage. This passage pulse-pumps additional fuel into the carburetor as it runs. Hope this helps!
Jan 14, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Saw runs fine for about 15 minutes,then the idle speeds up,then it dies,almost like it is flooding
Do aclean or overhaul of all fuel components.Change the spark plug or the coil aka=spark plug cable.But if your saw in lees the 2 yrs you need to follow the starting guide in order to avoid flooding.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 11, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a Poulan Woodshark Model 1850. It starts, runs for a few seconds and dies. Help!
Try fresh gas with correct oil mixture. Carb might need cleaning and adjustment. Also try leaving chock closed and see if it runs longer before dieing...if it does, it indicates that it's not getting enough gas which could be solved with the carb cleaning and adjustment.
Jul 29, 2009 | Poulan Garden
Garden Logo
892 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
