Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Power outage and freezer is now flashing "e" on display
I recently had apower outage and when the freezer was powered back up the display is reading E and the frrezer is not on.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
Posted on Jul 26, 2009
Refrigerator GTH18IBXWW Control panel lights not illuminated (refrig and freezer settings and read out). This after a power outage.
Unplug it and see if it resets after you wait 5 minutes and plug it back in. If the outage was caused by a surge, it may have damaged the control board.
Dec 22, 2015 | GE 18.0 Cu. Ft. White Top-Freezer...
True freezer
check the condenser and freon
Aug 18, 2008 | True Freezers
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Hello I have an HMCF7W1 Magic Chef freezer, after a power outage the power light comes on, but the Run light will not turn on and everything is thawed. What can I do?
Perhaps the power outage, was caused by your freezer?
When you think a reset would help, the run light should come on, after a little while. But perhaps only the thermostat is defect.
Be aware there can be so many causes, and none has to be related to the power outage, for your freezer not to work.
It would be virtually impossible to see what is wrong, from a distance. Better try to bring the food to a working fridge and call a tech to solve the problem.
Feb 08, 2015 | Magic Chef Freezers
After a power outage my Samsung SRS580DHLS is displaying and flashing SE? What does this code mean and how do I fix it? Rirht now the control panel only displays SE and does not respond to any presses
Your control board is reacting to a surge in power. Unplug the unit for 5 minutes then replug and follow normal starting procedures. If that does not work think about buying a new unit.
Oct 11, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Have power but not freezing, cannot hear motor, recently had power outage
Hello max ryan,
I understand that you had a power outage and now that power was restored, you have power inside the appliance but the freezer is not freezing and you can't hear the motor running. I would double check the breakers and make sure that they are on. You can also check the Temperature Control and make sure that it is not in the OFF position. If these solutions do not work, I would call the manufacturer for more help.
-Best Regards-
Jan 04, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
Dec 17, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
Mar 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
560 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
