Question about Transcend T.sonic 850 Digital Media Player
"insufficient power" while charging
Hi... i purchase Transcend 850 5 months back. now i am not able to charge it. when i connect the usb cable to my computer a message "insufficient power" is getting displayed in the player. con yuo give me a solution....
  • 153 Answers
Well there is some problem with ur power supplyand it needs physical assistance get it checked by an expert. nad please read the menual.
Posted on Jul 26, 2009
  • 1 more comment
  • babjan
    babjan May 02, 2014
    1.Power off / shutdown ur device.
  • babjan
    babjan May 02, 2014
    1.Power Off / Switch of device complete 2.Goto online http://in.transcend-info.com/Support/DLC... . select ur 8gb/4gb player (option) right one, download firmware extract file when transcend programme open take ur device to ur hands nd hold the "MENU" for device connect , when device shows firmware version release the MENU select firmware update (OK)
  • babjan
    babjan May 02, 2014
    After Firmware Update successfully Press OK. GOto player Menu Settings Change DAte Time Location nd connect ur device with PC It Shows same message change the USB data cable Original White Color Cable.
Compatible charging cables for phillips go gear hdd1630/17
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Philips HDD1630 MP3 Player
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
I bought Transcend MP860 last month. when i start charging thru PC it shows the message charging error insufficient voltage.When I finish charging it fully until it displays the message and start playing...
This is a common problem with these players (first link). My MP860 failed in this way (insufficient voltage etc message)
I made a rig with laboratory PSU (several amp output) connected to USB socket and I know that that the problem has nothing to do with voltage (voltage was stable 5V - tested also higher up to 5.5V)
For a while a trick with holding the volume up button worked for me. (see second link) But once I discharged the battery to a too low level and the trick did not work anymore.
My conclusion is that that message indicates Li-ion battery degradation and charger circuit/FW declines to charge it showing misleading message. (battery made by Foxlink)
I tore my the player open and rigged charge circuit and get it working again. Photo: http://farm6.static.flickr.com/5063/5683361395_d59bef8142_b.jpg
Few suggestions: 1. Never allow the battery to be fully discharged. Charge at any opportunity you have. 2. Once you get the Insufficient input voltage message try trick with holding volume adjustment. 3. If 1., 2. failed rip it open and make charging circuit or replace battery. 4. Do not buy Transcend MP3 players. (?)
http://ec.transcendusa.com/forum/viewtitle.asp?BoardID=42&TitleID=915&Page=1
http://www.mouthshut.com/review/Transcend-MP-860-rnlstlqtln
Apr 11, 2011 | Transcend T.sonic 610 MP3 Player
Trancend pod not detecting
Go to Settings->USB
Under USB, you can see two options like, USB and MTV. Select USB.
Now Try again, it will work.
Cheers...!
Mar 15, 2010 | Transcend T.sonic 850 Digital Media Player
When i connect to usb port it says insufficent power supply. What should i do
You will need to buy get a POWERED HUB,as the USB port can only supply 500mA and your device needs more.
Feb 21, 2010 | Transcend T-Sonic 840 MP3 Player
Problem with Transcend Mp4 player
my ipod transcend t sonic (850) nt showing foders of video an audio
Jul 15, 2009 | Creative Labs Zen V MP3 Player
T Sonic 840 "Insufficient power"
If this message persists no matter how long you charge the device then it is an indication that the battery has failed. Your best bet would be to contact Transcend for repairs.
Jun 24, 2009 | Transcend T-Sonic 840 MP3 Player
TRANSCEND IPOD NOT READING WHEN CONNECTED TO ANY DEVICE LIKE COMPUTER OR HOME THEATRE SYSTEM. INFACT IT IS GETTING CHARGED BUT NOT ABLE TO READ DATA WHEN CONNECTED TO USB OF ANY DEVICE.tsonic 850 4gb
When the ipod is connected to Computer or any other device, it will be in locked stage, you cannot view anything in the player, instead you can do anything from the computer.
This is the expected behavior of the music player.
So, don't need to worry about it.
Cheers...!
Mr.Maduraikaran.
Dec 27, 2008 | Transcend T.sonic 850 Digital Media Player
I have a 605 wifi and it sits in the charging platform. I cannot get it to turn on past the Archos titile page and then it seems to fade and fail like there is no power. It is only 8 months old. Is the...
Hi have you got your power supply plugged into the charging platform??, It would appear you have insufficient charge in the batteries on the 605.
If you have the USB lead plugged into the charging cradle this would normally ask you to select either charge or usb.
What does the CHG. light on top of the 605 do when you plug the unit into the cradle ?? (steady green-- charging. flashing green-- fully charged)
Dec 03, 2008 | Archos 605 WiFi Digital Media Player
Transcend T.sonic 850 Digital Media Player Logo
417 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
