Dvc stops rotating
The 3.15v on the main motor fluctuates bitween 0.02v and 3.15v.The power suply is a steady 4.9v.
can you help??
Regards,
Srulik.I.Haramaty
4Z4JT
  • 35 Answers
Firstly, check if there is a resistor that blocks the power,if not there is capacitor that is associated with the circuit that is bad,check very well.
Posted on Jul 26, 2009
SHARP AR5620SL CODE L4
  • Code: L4 01
  • Description:Main motor lock detection. The main motor does not rotate. After rotation of the main motor, the motor lock signal is detected for 1 sec or more. During rotation of the main motor, the motor lock signal is detected for 1 sec. When the main motor is stopped, the motor lock signal is not detected for 5sec or more. (Though the motor is stationary, it is judged as stable rotation.)
  • Causes:Main motor unit abnormality Improper connection or disconnection the main motor and the harness. MCU PWB abnormality
  • Remedy:Use SIM 25-01 to check the main motor operations. Check connection of the main motor harness/connector. Replace the main motor. Replace the MCU PWB.
Sep 08, 2017 | Sharp Office Equipment & Supplies
I have kyocera km1500 and have a error of 4200 then what is the solution?
Code
C4200
Description
BD steady-state problem
• The MIC detects a BD error for 600 ms after the polygon motor rotation has been stabilized.
Causes
Defective laser diode. Defective polygon motor. Defective main board (KP-5060).
Best Regards
Jul 24, 2016 | Kyocera Office Equipment & Supplies
Juki lk1903b machine is not working E7 is appers
HI
regarding JUKI LK-1903B Eror E7:
1-Machine lock error ( The main shaft of the sewing machine does not rotate due to some troubles ). please check if machine rotate smoothly by hand or not.
2-main motor problem ( AC servo motor problem ) motor part No.:401-38137.
3- check connection CN-15 / CN-17 from SDC board to main motor.
4 - problem in SDC servo board ( No output for main motor ). SDC servo board part No.:401-42267.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Apr 10, 2015 | Juki Sewing Machines
Can i put Nvidia 7300 SE 512mb 64bit video card on hp dc7600sff with 240 watt power suply will it work and not burn or overheat power suply or some other part?please help
Hi.
Yes you should be able to install that card in the DC7600 as it is a low profile graphics card, however i would think about upgrading the power supply as 240 watts might be a struggle for the computer.
Regards.
Feb 02, 2013 | HP Compaq dc7600 Small Form Factor PC...
When i push the power buton the powerled go on and few secons off again i used the powercord suply and the battery suply. Could i be the power suply I.C wiht best regards Andre
Hi
Try this. Remove Battery. Hold power button for 10 to 20 seconds Insert Battery and switch system on. Let me know if this works
Oct 01, 2010 | HP Compaq nx6125 Notebook
Freud 3 one fourth plunge router variable speed won't run
Hi
First check the power suply cord(conductivity),the on/off switch, the fan and the armature,the brushes and the wires.
best regards savumihai71
Jan 05, 2009 | Freud FT2000E 3 Router
Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Dec 30, 2008 | Kyocera KM-1505 Copier
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Oct 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Relay won't stop clicking
Matt, sounds like you have a main board problem here. The main board is on the back side of the refrigerator. If you are handy with a meter you can do some checks. Is the clicking relay coming from the main board? If it is, than it's more than likely your problem. First check the voltage from connector J7-9 (orange wire) to blue harness to the left, terminal marked line. This should have a steady 120V, no fluctuation. If you don't have this, replace the board. You want to make sure that the condensor fan motor and evap fan motor are not shorted. A shorted motor will take out the board. At the fan motors harness, with the power off, if you read less than 1K ohms between white to red or white to yellow it's bad. This is for both the evap and condensor fan motor. The part number for your board is. WR55X10543...Catriver..post back.
Mar 11, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
