Question about Samsung PPM42M8HB Plasma TV
Sound only with a black screen.
I have had my SAMSUNG flatscreen for 1.1/2 years with no warrenty, and I have a big problem it's BROKEN much to my dismay. The screen turns on with a picture and then instantly goes black. I have sound only, it has been tested through SAMSUNG by checking to see if the menu comes on with no SKY. It does not. So they said it was not a problem with the sky but the TV. Please advise. Surely a TV should not have broken down after such a short time. A very upset SAMSUNG customer. Plus I was told it would be 30 pound call out and 45 fee to fix.
  • 585 Answers
Sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in if you have a soldering iron
Posted on Aug 01, 2009
42 inch plasma Samsung less than a year old with a crack in left corner has sound black screen??
Hi, If the warrenty is still good bring it back to where you bought it. In time the screen will go totally black. So replace it. Good luck.
Jun 20, 2011 | Televison & Video
Why is my new samsung lcd 32 inch getting on and off again and again it self? and a voice it coming from the back part too.?
Under a year,this tv was bought?Tv still have warrenty,call Samsung for warrenty repair.Not.Tv power on have flashes of pictures,few sec.than dies,have only sound left?Yes.Ur tv have dead 1 or 2 long board call the LCD inverter boards.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produre a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 LCD inverter long boards for the replacement.
Aug 09, 2010 | Samsung LN32A550 32 in. LCD TV
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
5 year old synphonic 37 inch (regular) TV has recently started making humming/buzzing sound similar to when reception is weak (picture is clear). TV is connected to cable and none of other TV's have...
Open the cabinet of the tv,on the FBT,the big black block of plastic with a red wire with a cap to the CRT tv tube.Near the base of that big black block of plastic have a 3' steel rot on the block,glue that with some super glue,will solften the noise alot or stop it all together
Mar 08, 2010 | Televison & Video
My Samsung 47 has a black film covering 1/2 the screen for about
Samsung only makes TVs that last 2 years, mine also has the same problem. Throw it away and buy a cheaper disposable TV, despite all the hype Samsung is just another cheap and nasty manufacturer who uses its customers as product testers. Why do you think they keep changing model numbers every week ?
Jan 13, 2010 | Televison & Video
Samsung flatscreen lcd picture went out 18 months after purchase. I hear sound but see black screen.
i have had to repair a few of those and the best! info i can give you is this!! the main board has to be swapped out! there little that you can do to repair it most of the parts are manufacturer availibility only! and non serviceable! by the user most boards are shipped complete at a cost of $90-$160 depending on supplier and area.
Jan 12, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Sound but no picture is it the picture tube or just another problem
most likely will not be the tubes mate, if the tubes go then you just get a big mix of red green and blue colours in the screen - sound but no picture is more likely to be the starter unit on the flat screen.
flat screens have a starter unit - mine went on a samsung but under warrenty
Sep 08, 2009 | Sony KP-53HS20 TV
My console has turns on but doesnt show on screen or sound anymor
If your xbox is broken contact microsoft support at http://support.xbox.com/ . If your xbox is under warrenty it will be free else you will have to pay a little bit if it is no longer in warrenty. Their toll free number is 1 (800) 4MY-XBOX
Jun 08, 2009 | Microsoft Xbox 360 Console
Lg 50 inch plasma tv no picture or sound
There are several pcb's that can cause this. Ihave found that the Z sustain pcb is the most common one though.
Jan 08, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Samsung PPM42M8HB Plasma TV Logo
218 people viewed this question
Jerry Greenberg
Jerry Greenberg
