Question about Dishwashers
On my GE dishwasher (model GSD4020Y70BB), the main detergent cup cover will not close. I've made sure the selector knob is in the OFF position - but the cover still will not close. I'm afraid if I put any further pressure on the main detergent cover handle, it will break something.
  • 52 Answers
Sounds like the clip that holds it shut is either broken or could be clogged with soap ....check and clean or replace
Posted on Jul 26, 2009
GE Dishwasher Detergent Cover won't latch
You should read the manual of your dishwasher where you will find solution for sure.
Mar 13, 2014 | Dishwashers
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
The detergent cup lid stopped closing on my old GE Model # GSD600G-0l dishwasher. Tried turning the dial clockwise to the Off position, but it won't work.
heatman101
May 10, 2011 | GE Dishwashers
Hello. I have a GE Potscrubber 600 dishwasher. The soap dispenser will not close. This seems to be a common problem. Any help would be great, thank you.
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Oct 24, 2010 | GE Dishwashers
The detergent cup will not close on GE GSD5120 dishwasher
they get warped and the latch gets waren out . replace the cup assy . this is a common repair . mm
Dec 08, 2009 | GE 24 in. GSD5120 Built-in Dishwasher
Small door where soap goes does not open during cycle.
Most detergent cups are spring loaded and released by either a mechanical trip or by a bi-metal strip latch. If your model is a simple dial timer type, look for a mechanical linkage between the timer and detergent cover. If it is a touch panel control, look for the other type. The bi-metal strip type has a heating wire wraped around it that can open electrically or burn out physically.
Mechanical types can be checked by rotating the timer knob 360 degrees while watching the detergent cover linkage. Electrical types require use of an ohm meter to check the resistance of the heating element on the bi-metal strip.
If you are using powder type detergent, make sure it is not caked when added to the cup or it can jam the rotating type covers.
Feb 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Profile PDW9200J dishwasher leaves a film and dirty dishes
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
Dec 20, 2008 | GE 24 in. Profile PDW9200J Built-in...
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
182 people viewed this question
Top Dishwashers Experts
