Question about LG 42PX5D 42 in. Plasma HDTV
Thin vertical red line down screen - LG 42PX5D 42 in. Plasma HDTV
  • LG Master
  • 458 Answers
This can be caused by either the FFC (Flat Flexible Connector) from the address board to the screen. There are a few of these connectors so you need to judge from the position on the screen as to which one is at fault. You need then to dismantle the main board to gain access & then remove the heatsink running along the bottom to gain access to the board, you need to carefully disconnect the cable & try to clean the contacts, then re-assemble. This can sometimes cure the problem, but I have had this fault a few times & have only been sucessfully a couple of times because inevitably the fault is internally within the screen itself & cannot be fixed. The only solution then is to replace the screen which can be costly I'm afraid.
Posted on Jul 30, 2009
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
There is a vertical red line that runs down the screen on our Sanyo TV. It is just a thin line but it is annoying because you know it is there. Any suggestions?
thin lines are associated with the connection of the pixels on the screen in the grid. If its under warranty get it fixed before expiry as its not a cheap fix.
Red lines are not convergence problems they are component problems so you cant adjust it out
Sep 13, 2009 | Sanyo DP26746 26 in. LCD Television
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Feb 25, 2008 | Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
LG 42PX5D 42 in. Plasma HDTV Logo
187 people viewed this question
Computer Repairing
Computer Repairing
