Question about Dishwashers
Dishlex Global 310. Was working okay, then stopped with all lights on the right hand side flashing and a regular beep. No response when any other buttone pushed so I turned the power of and on and heard a beep but no lights or response when any buttons pushed. Held 'pause' and 'program' buttons down together but no response. Can you help?
  • knox_rob Jul 27, 2009
    Tried that before. If it was the child lock that solution should work within seconds but did not even after a minute. It does beep when turned off and on at the power.
    Should I try again or is there something else I can do?
  • knox_rob Jul 28, 2009
    I followed the second solution. The dishwasher beeps when the power is turned back on at the wall but no lights and no response when buttons held down for 15 to 20 seconds. Will do it again but I don't expect anything different.
    Please email me when you post a new solution.
  • 10,865 Answers
Hello Rob. The Dishlex is made by electrolux. If yours is rather new you have a 2 year warranty on labour and a 10 year warranty on parts. that being said, if yours is under warranty working on it yourself will void the warranty.
if yours is older and you want to fix it yourself you will need a new circuit board. good luck with it.
Posted on Jul 28, 2009
  • 1,272 Answers
HI,
1)Unplug it for 30min and then plug it back on.After this go for a fast cycle.See if this helps to clear the error.
2)You cant try turning the tap on faster.I believe it is not getting enough water.
3)If you still face the problem then you will have to replace the electronic valve (the thing the hose goes into) which requires a physical presence of a tech.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 27, 2009
  • 1,170 Answers
Hold the start/pause and program button at same time till machine beeps. That should reset it.
Posted on Jul 26, 2009
Dishlex Global 310 dishwasher fills then stops with flashing "fast" light
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 13, 2008 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
