Question about Hotpoint Freezers
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
My Hotpoint Fridge freezer FFA74 Freezer Door Will not close with the draws in. The Draws a as far in as they can go.
  • 1 more comment
  • jsbe4 Jul 27, 2009
    I have Since Done some More research and have discovered its something to do with the inside of the freezer.... there is something frosting up causing the back panel to push out in turn not letting the draws go all the way back thus stopping the door from closing....From what i have read Hotpoint will charge an arm and a leg to fix it!
  • Hilary Robinson Oct 03, 2011
    Did you get this sorted? I have the same problem!
  • Marom Oct 08, 2011
    I have the same problem too, has any of you got the solution?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Posted on Jul 26, 2009
  • harold nesmith
    harold nesmith Jul 27, 2009
    sounds like u have a clogged freezer drain or possibly a defrost problem.. either way frost or ice is building behind freezer panel. remove panel and check that drain will allow water thru to bottom drip pan. if thats ok and u have thick frost on the coils, u may have a faulty defrost heater or timer. please rate me.
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Hotpoint FFA74
May I ask what the problem is? Just clean up the icecream
Jul 01, 2013 | Freezers
Freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 17, 2010 | Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Hotpoint FFS70 freezer door won't close
there must be a basket that is bent ,
Jan 18, 2008 | Freezers
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer problems
you could try a 3 in one hard start kit... comes with a copacitor to help start compressors with age and having trouble starting
Sep 04, 2007 | Freezers
Freezers Logo
492 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
christian nielsen
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
