Question about Acer Computers & Internet
I have a brand new Acer Inspire 5516, purchased for the wireless function. Have a DSL modem in the same room. Can't get the Acer to work wireless, only with the modem connected. What am I doing wrong? Or what is missing from my equipment? Doesn't seem to be anything wrong with the computer or the server. Internet will come on but doesn't seem to be able to open a page. Your advice.
    President:
  • Acer Master
  • 1,314 Answers
You need to have your DSL modem connected to a wireless router. The wireless router will then put your internet connection on the airwaves so your Acers will connect wirelessly to the router then they will be able to access the internet.
Posted on Jul 26, 2009
Can you help me connect my Zonet Wireless AP Router ZSR2104WE now that I have purchased a new modem (Motorola DSL Modem 3360)?
You must hook these particular items up in a specific sequence. First power down both the modem and the router, only connect the modem to the isp until all appropriate lights on on. Next plug cat 5 to router where it is labeled internet or wan if neither label then to #1. until alights come up on router. Hope this helps.
Sep 06, 2012 | Zonet ZSR2104WE Wireless Router
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
I have purchased an AT&T 2wire 2701HG-B wireless DSL router to use in setting up a wireless network in my office. I have an external modem now that is part my AT&T internet service. Will the new...
The network appliance you're asking about is a modem with a wireless router built in. Basically, it's an all-in-one device. It will replace your already existing modem. It is a wise upgrade for any AT&T DSL connection.
Mar 12, 2011 | 2wire 2700HG-B Router (2700HGB)
I have a siemens 4200 adsl modem i had a net gear modem before and that was not working with wireless internet and now this modem wont let me connect wireless either only with the ethernet cabel. help!
Hello Mate,
the siemens speedstream 4200 is a DSL modem/Router which doesn't have wireless connection. So even tough if you have a computer equiped with a wireless adapter, you will not be able to connect wirelessly because the siemens 4200 doesn't act as wireless access point.
You may need next time to check first if the modem/router to buy support wireless (wifi g or n) and make sure that it's not only a modem, it should be also a router.
i attached here some references for you from the top brands:
1. Linksys DSL modem/Router with wireless N: http://www.linksysbycisco.com/MEA/en/products/WAG120N
2. Linksys DSL modem/Router with Wireless G: http://www.linksysbycisco.com/ANZ/en/products/WAG54G
You can find other brands as Dlink, Netgear ...
Best Regards,
Oct 29, 2009 | Computers & Internet
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless problem
maximum cord length is 90 feet otherwise there is a resisitance factor that will lose its signal as you described
Aug 31, 2009 | Computers & Internet
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
I have a DSL router provided by frontier. I am trying to make my desktop wireless. I believe that my DSL router functions as a modem also. I purchased a Linksys wireless broadband router. I can't not...
Your router should just be that, a router. Your connection is probably like fibernet the modem is actually on the outside of the house. This may help or may not but I have a linksys wired router that works very well but you have to go to their website in order to set up the router. You may need to look through your papers and find the web address to connect to the right site.
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
299 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
