Question about Pioneer DEH-P7600 CD Player
LIGHTS ON NUMBERED BUTTONS???
Headunit has reset its self somehow, anyone know how to chage the backlight colour for the buttons 1-6 on the head unit to RED from green??
cheers
  • 709 Answers
Go to Www.pioneerelectronics.com and support. Find the CD palyers manual and look on pages 41 through 50 in initial settings to see if any of these settings effects the colors of the 1-6 buttons.
This URL below is supposed to get you the Manual, but I am signed in on the pioneer website, you may need to sign in first before using this URL.
https://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/50622965OPERATION%20MANUAL%20DEH-P7600MP.pdf
Posted on Nov 24, 2007
Why does the unit beep when I plug it in.
Good Morning Tina,
I understand that your Frigidaire air conditioner, model# FAM187S2A, beeps and flashes lights when you first plug it in. First, test the power supply cord by doing the following:
1. Plug in your air conditioner.
2. The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
3. Press the RESET button. Again you will notice a click as the button engages.
4. The power supply cord is now supplying electricity to the unit. (On some products this is also indicated by a light on the plug head)
NOTE:
• Do not use this device to turn the unit on or off.
• Always make sure the RESET button is pushed in for correct operation.
• The power supply cord must be replaced if it fails to reset when either the TEST button is pushed, or it cannot be reset. A new one can be obtained from the product manufacturer.
• If power supply cord is damaged, it CANNOT be repaired. It MUST be replaced by one obtained from the product manufacturer.
NOTE: Some plugs have buttons on the top.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire FAM187S2A Air Conditioner
Clarion Marine Problem w Sirius CeNet Unit
When a CD changer or Sirius satellite receiver is added to a system, the source unit’s main wiring harness must be disconnected before the changer and/or satellite receiver’s CeNET cable is connected to the source unit. Otherwise, the source unit will not “recognize” that a CD changer or Sirius satellite receiver has been added.
Apr 09, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Somehow I am getting "button locked" on every button but the power button. Does anyone know how to fix this??
A factory reset on several AOC models can be performed by unplugging the TV for 5 to 30 minutes. When it comes back on it should be reset to factory defaults and ask to do a channel scan. You have somehow enabled the so-called childproof or "Bar mode" of the TV which deactivates the panel buttons so kids (or patrons) cannot mess it up.
Sep 08, 2013 | AOC L24H898 24 in. LCD TV
I need a printout for instructions to set an Intermatic EJ 500C digital wall switch
I have a intermatic house timer to turn on and off the outside lights We moved in 5 years ago to this house. One evening somehow the lights did not turn on or turn off when programed. I accidentally reset the system by pushing the reset button instead of the on / off button. I dont have a model number of the timer to look up, maybe you can tell me where I can find it on the device? or general instructions on how to set the system to go on when the time is set and of . I was hoping to see if I can find a model similar to one I have. I saw one close but I dont know its the same or not.500c or maybe a model 10 years ago plus. By the way it has a battery conpartment using a single AA battery. The best description I can give you is its white in color...rectangle has a display screeen on top of the unit....and has 6 soft push buttons ....3 on to , 3 on the bottom....top row of buttons has MODE ON/OFF EVENT...RESET the bottom row has DAY...HOUR....AND MINUTE..Please advise
Apr 05, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Rear Wipers
You need to try reseting the control head. You need to push and hold the the upper and lower buttons on the left side of the control head untill all of the lights start flashing. It will cylce through a flashing lights sequence and then everything should be working fine.
Aug 29, 2008 | 1997 Dodge Caravan
LC37GA8 RESET
You must unplug the unit, and while unplugged depress the volume up and channel down buttons at the same time (the buttons on the tv) and while buttons are depressed, plug the power cord in. Hold the buttons for 1 sec. then release. The unit should no be on in the service mode. A small k should appear on the screen. With the remote press the channel up button. There should now be a menu on the screen where you can see lamp error line. The lamp errors will most likely read 5 and 5 lamp errors in this unit will cause shut down. Use the channel down button on the remote until you highlight that line. Withe the curser right arrow button select the 5 and now with the channe up button you should be able to reset the 5 to a 0. Now unplug the unit and wait 30 sec. before powering the unit. That should return the unit to normal operation.
Oct 24, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Sony CDXM 8800 Xplod Car CD player won't repond when buttons are pressed
There is a reset button on the area behind the faceplate. You will have to go back in and redo many settings but just hold the tiny button down with a ballpoint pen for 15-30 seconds and it should reset allowing the faceplate buttons to operate.
Mar 01, 2017 | Car Audio & Video
Love my new Saitek Keyboard, but I don't what some of the buttons do???
You can download a manual here: http://www.saitek.com/manuals/eclipse_manual.pdf For the 1, A, and Down Arrow: My guess is that these are actually the indicator lights for Num Lock, Caps Lock, and Scroll Lock. For the four silver round buttons: The top right corner of your Eclipse keyboard features a set of controls for changing your computer?s audio volume and the brightness of the Eclipse Keyboard?s backlighting. To reduce audio volume, press button A until the desired volume level is reached. To increase volume, press button B. To mute the audio output, press button C and press it again to cancel mute. Press button D to control the brightness of the backlighting. Press the button to scroll through lights off, lights full brightness and lights half brightness.
Apr 18, 2007 | Saitek PZ30AU Keyboard
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
Pioneer DEH-P7600 CD Player Logo
257 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
