Question about Refrigerators
Excessive water dripping - Refrigerators
  • 3 more comments
  • manny_chen Jul 27, 2009
    Dear Ted062,
    It is an LG Refrigerator-Freezer 2-door no frost model # GR-S352QVC.
    The problems are:
    1. Excessive water dripping from inside the refrigerator collecting in the lowest portion at the bottom of the vegetable rack and the water is spilled out of the refrigerator every time the door is opened.
    2. The compressor doesn?t seem to stop working or working continuously. My understanding is the compressor is supposed to stop and resume automatically depending upon the temperature setting.
    3. The compressor sounded noisier than usual.
    Thank you for your kind help.
    Manny Chen
    Dear Guru,
    The problems are:
    Manny Chen
    Dear Guru,
    The problems are:
    Manny Chen
  • ted062 May 11, 2010
    where is it dripping from the inside to the floor? or what?
  • Mike Smith
    Mike Smith May 11, 2010
    Brand and model number needed .
2 Suggested Answers
  • 246 Answers
SOURCE: excessive water dripping from exhaust
Try to use 3oz pure accetone available at sally beauty supply and 1 oz of Xyline available tat Home Depot, Thay will clear your engine from sludge. Use cheap oil and repeat copule of times.That is per 10 gallons of fuel.
Posted on Feb 13, 2010
2003 Saturn vue v6- excessive water, moisture dripping out of tailpipe- same vehicle that's making the roaring noise
Water does drip out of the tailpipe as a matter of course. That's perfectly normal.
If you have a 'roaring' noise from the silencer/muffler area it's probably because there's a hole in it due to age/corrosion and the exhaust gases are leaking straight to atmosphere without being silenced by the muffler.
Water WILL drip from a holed silencer or pipe. This is normal. The water isn't your problem - you have a hole or split in the muffler or pipe
Mar 21, 2016 | Saturn Cars & Trucks
What is the cause of water dripping out exhaust pipe and engine smoking excessively?
Cold weather right? Dripping is the water condensing from the exhaust gases. The "smoke" is more than likely water vapor, just like your breath in cold weather. If you have smoke (black) in warmer weather, you have an excess fuel problem and won't pass emmision tests. If blue smoke you have oil leaks into the coubustion chamber. Also will not pass emmisions test.
Mar 04, 2015 | 2003 Ford Explorer
This is a snyder general ceiling mount unit. During the defrost cycle the unit drips excessive water into the catch pan. I installed a new condensate pump and it seemed to help. About a week later same...
You must live in a area with high humidity. Could adding a nice de-humidifier help maybe? How tight is the house? Might need more insulation maybe? Your drain line might have a bend in it causing the water to back up and overflow back into the drip pan.
Sep 24, 2013 | General Electric 5kcp39dgp089s...
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
There is a excessive amount of water collecting in the drip pan, and I need to empty the pan every other day. Before it was once every two weeks or so. I have taken the "unit" apart to clean the...
Hi
Excess water going into the drip tray is usually an indication of the grind being to coarse. If your pucks are not solid but just fall apart this is the case. When the grinder is grinding, turn the big knob in the bean hopper down 2 numbers smaller and see if this changed. If you have a second knob in the bean hopper change the to the plus side, but not all the way to the plus. Do this first before you change the grind setting. Excess air between the grind allows more water in the brew unit and when it is done it goes into the drip tray.
Mar 23, 2011 | Solis Master 5000 Espresso Machine
Atwood g6A-7E wont turn off keeps heating water till tmp drips
Some dripping at pressure relief valve is normal, but are you saying it continues to run excessively hot? Does water in trailer feel extra hot?
The ECO, and/or Thermostat, should cut the power/flame before it gets too excessive.
Apr 03, 2010 | RTO Atwood Water Heater - 6 Gal LP
Excessive water dripping from exhaust
Feb 10, 2010 | 2004 Ford F150
Kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Jan 15, 2010 | Heating & Cooling
WATER DRIPPING INTO REFRIGERATOR AND FREEZING
Chances are, your doorseals are shot. This will allow excessive moisture into the unit.
Jun 25, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Excess water in the over flow pan
if your drip ban is full is because one of the doors stay open
Mar 25, 2009 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
