My system on some time press the power button other wise it doesnt work.while short the power pins in mother board it work .is it problem with the power button or cable
  • 23 Answers
It sounds like the power botton has become damaged
Posted on Jul 26, 2009
Power
It could be because of your Switch Button, To find out the problem open the case and find out your switch connector wire which goes and connect to the motherboard. Now remove those wire and try shorting power switch connector with and metal or with screw driver. To short the power connector you need to find out the proper two pin on the mother board. after doing all this if you can switch on your computer at once then you know what is the problem. If not then just let me know.
Aug 10, 2012 | HP Pavilion Computers & Internet
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Dear sir my motherboard not display i will cheack ram, bois,smps
does ur processor fan and smps fan work if both are working then the problem is in the motheboard if both are not working check ur smps by shorting the green pin with black if it doesnt work change ur smps and it works the problem is in ur motherboard ur power supplysection in ur motherboard has been fried take the mother board to a qulified chiplver service personal
Sep 27, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
When i turn my comp on the lights and fans start for about 1 or 2 secs then stops my make of comp is zoostorm
Pleease remove all connections (including Front Panel pin assignments) from Mother Board except Power Supply.
Now find out reset pin assignment on mother board and shot that pin if its woking then again do all connection and try.
other wise dismental complete system and re-assemble sytem. your problem will be solved
Mar 20, 2010 | Computers & Internet
I have a pc3500g motherboard and need to know where to plug wires
Dear... Mr.A. Ganesh
From Chennai(India)
pin configurations are printed in the mother board.watch carefully .it may be just few inches away from the front panel connector.
Even u cant find it...
you dont worry about it.You just assemble the
Cpu ,SMPS
then switch on the main .
then short a moment( 1second ) at any two pins which is in the front panel connector ( using tester/sqrew driver);continiously cheak like this one by one pair of pin(Verticaly and Horizontaly).
when you short the corrrect pin,then system on.so you can find it like this.then connect the power button easily.
I am 5 years Experienced Engineer. Mother Board should not get any problem doing like this.
Thank you
Feb 12, 2010 | Computers & Internet
I need to get my powwer supply to turn on without my motherboard.
well if u want see your fans working without connecting the power supply you can short the green wire (pin) with any ground (black) to see your fan work.....
use a pin or a piece of mettal to short green and black pins
Apr 07, 2009 | Computers & Internet
Computer will not boot
Option 1 :
Remove completely the mother board from Cabitnet.
Try to check it on other Cabinet.
Option 2
Remove mother board and re- plug the SMPS power Connecter to Mother board outside of cabit and make sure that motherboard is not touching directly to Metal part of cabinnet.
then switch on computer and check
Nov 22, 2008 | ASUS P4S800-MX Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
David Payne
David Payne
