Question about Westinghouse Dishwashers
Westinghouse SB915 wont heat up water
Tried resoldering joints on PCB on relay checked heater element and read 26 ohmsany ideas anybody please
Found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Posted on Feb 04, 2011
  • mrctosee
    mrctosee Nov 15, 2012
    where does the circuit board located?
Dishwasher not heating
I am guessing the hot water is not hooked up. Depending on the type of dishwasher and the setup of you kitchen, you can try to hook it up. You will need to pull it out to fix the heating.
Elisa Jed ' http://www.orlandoac.com/
Mar 24, 2014 | Westinghouse SB915
Water not heating
water not heating I need some ideas to fix the problem.
Nov 18, 2012 | Westinghouse SB915
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
My Westinghouse dishwasher SB907/915/925 is not heating water.
I have had the same problem. I removed the heater element and checked the resistance with my multimeter and got the reading of 26.4Ohms which sees ok. I then removed the printed circuit board and found that a joint on the back had burnt out. I have resoldered this joitn and all seems fine now.
Jul 14, 2010 | Westinghouse 24 in. MDP531 RF...
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
My westinghouse SB907 diswasher stopped heating the water so I took the board out and found a relay which had a blown solder joint so I replaced the relay and now the water heats, the problem now is the...
solder joints are a common problem most times all they need is a resolder.if you are sure you replaced the relay with the same, i would suspect you have another dry joint go back over them and resolder all of them.But i have a feeling the relay is not the same recheck the part number it might be for a older/newer model.adrian;;;
Dec 02, 2009 | Cars & Trucks
Westinghouse dishwasher virtuoso SB 925 not heating the water and not drying the dishes , still workig thou. Would it be expensive to repair?
I also had this problem of the water not heating up but the washer still did its thing. what i found was the problem, is the soldered joints on the circut board were cracked (dry joints) around the relay area, i just resoldered them and hay presto its all good
Aug 20, 2008 | Dishwashers
Westinghouse sb915 will not heat element shows 25 ohms when tested.
Westinghouse SB907 had same problem, which I had thought might be the heating element. Fixed relay soldering on PCB where it was burnt/melted, now works! This probably applies to the Westinghouse SB925 also.
Jun 02, 2008 | Dishwashers
Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
May 08, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
900 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Tom Chichester
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
