Back to:
Tags:
Amana ABB1927DE Bottom Freezer Refrigerator
Amana refrigerator only not working (by 3 users)
posted by angelfacemld on Nov 21, 2007
The refrigerator section has no cold air blowing in.    The freezer section is working fine.
The freezer is working fine, but the refrigerator part is warming, AGAIN!! This will be the 4th time it has happened. There is a frost buildup on the back of the freezer panel and has been each time. Each time we have just unplugged the entire appliance and let the freezer defrost. Once we plug it back in the refrigerator gets nice and cold again. We thought the problem was with the ice maker so we did not use the ice maker this last time, but it still frosted over. It has been about a month since the last time this happened. We have vacuumed out the vent on the bottom and the back. What else can we do before we have to call a repair man?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 09, 2008
Do we need to cal the maytag repair guy to change the defrost thermostat or this is an easy fix ? If we can do it myself, please give us info how to change it.. Thanks
Comment by Ross_t, posted on Jan 02, 2008
Same problem has just occurred on my Amana. I plan to troubleshoot the frezzer defrost thermostat tonight...
Best Solution
posted on Oct 07, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Re. the above solution it would be wonderful to show a drawing of the back of the refrigerator and how to remove the back panel. This would be helpful in finding the defrost thermostat.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Amana refrigerator only not working:
I don't want to Accept this solution
Solution #2
posted on Nov 22, 2007
Helpful (85)
supertechks
Rank:Wiz Wiz
Rating: 92%, 58 votes
Model # important.
You have a failure of the defrost system. There are 3 components not counting wire and connectors. Most likely it is not the heater that leaves the defrost timer then the defrost thermostat. My guess is that the defrost thermostat is bad (just a guess for now) Need more info to help you more. If you know what and where the defrost timer is then advance it clockwise till you hear a distinct click, not the little clocks you hear during turning it, a distinct click. If after about 10 minutes you notice the frost down low on the freezer rear interior wall melting. Replace the Timer it is bad.
If this makes no difference then I am betting you have a bad defrost thermostat and it is located on the top right part of the freezer cooling coil behind the rear interior wall of the freezer behind the frost.
supertechks
Thank You!
Solution #3
Not Rated (0)
Ross_t
Rating: 0%, 0 votes
My issue was with the defrost thermostat. Solved my defrost problem. Now I have what sounds like a compressor knock.
Thank You!
Can you Help with these Refrigerators problems?
top cool enough bottom not cold enough to freeze food
The door handle on the bottom freezer is loose. I do not...
I have an amana bottom freezer that is not freezing food....
1997 Amana bottom freezer refrig model BCE20TW icemaker is...
A strong purring like sound keeps repeating until you open...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
