Question about Garmin nuvi 255W GPS Receiver
When I s/w on it comes onbut a blocking message comes up saying no details maps found. I am using this for past 10 months.
  • Garmin Master
  • 2,130 Answers
Please see this link. I can help you with this issue. It's because you have a corrupted or missing map inlock code.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Posted on Jul 27, 2009
Garmin nuvi
This is an indication that the map or map unlock key is either missing or corrupted. If you have registered your unit with Garmin, try connecting to your PC and try downloading the map again. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Sep 30, 2013 | Garmin nuvi 200 Car GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My Garmin Nuvi 200 has a message that says No detailed maps found that support routing. The nuvi cannot be used without them. I just used this garmin a few hours ago, and it was fine. Now I can't get...
You need to call garmin to have them help you unlock your unit. It sometimes requires the 25 digit unlock code which they have on hand. 1-800-800-1020 I believe.
Aug 15, 2009 | Garmin nuvi 200 Car GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
"No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
Feb 20, 2009 | Garmin nuvi 350 GPS Receiver
Screen with message.. " No detailed maps found that support routi
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Feb 06, 2009 | Garmin nuvi 350 GPS Receiver
Updating maps
Press the power bar in the upper right c orner for 10 sec. and You will go into servicemood. Ther You can reset and run memorytests, Otherwise Use the lttle pihole under the tape on the bottom side
Aug 31, 2008 | Garmin nuvi 200W GPS Receiver
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message “No Detailed Maps That Support Autorouting” disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for “Getting your unlock codes”.If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the “No Detailed Maps That Support Autorouting” message.
Feb 05, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin nuvi 255W GPS Receiver Logo
91 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
