Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Thomson 40KW611S When switch on mains the Red LED will come on for about 3 seconds then starts to flash constantly. Noticed water coming from aerial input - have now disconnected and dried off with hairdryer - LED still as above
  • dean1982c Dec 16, 2008
    Mine is doing the exact same and wont switch on now, does anybody know the cause of this problem or how to go about fixing it, as my coverplan as expired just 3 months ago.
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
Chances are the water has managed to get into the tuner.or worse onto the main signal board. if you are in the uk you can try or call 01245302539 for part availability.
this is a job for a service engineer only.
Dont forget to get your aerial and cable replaced as it will happen again
Posted on Jun 11, 2010
My Thomson 40kw611s will not work when I try my remote. The light flashes on the switch and it stays in standby mode. It is not the batterys,fuse or anything. Can you help?
If it starts flashing when you press the power button on the remote, the tv is getting the right signal from the remote. You have a problem inside the set.
Oct 14, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Thomson 40KW611S - when switching set on, light flashes then goes into standby & cannot get to work.
this is an error code and directs the service engineer to where to lookfor the fault. I recomendyou contact a compertant service enginner to evaluate this fault for you as there are not much the layman can do.
Oct 11, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully...
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Jun 27, 2009 | Thomson Televison & Video
Thomson DTI6300-16, The amber light constantly flashes, no red or amber lights appear! any help/advise would be welcome
Does your Thomson DTi6300 fail to power on normally and displays a solid amber light? During the past few days we have been made aware of an issue affecting a number of our customers with a Thomson DTi6300 box. Customers have been experiencing problems with their box failing to come out of standby mode and typically showing a constant amber light on the front panel.
This fault is due to a broadcast issue which  has led to a corrupt file being loaded onto the hard disk.
Only Thomson DTi6300 boxes have been affected. If you have been experiencing problems of this nature first of all try switching your box off at the wall and leave for twenty seconds. If this does not work, please try the following procedure.
Please note this will unfortunately cause recordings in your programme library to be lost which we?re very sorry about. You may have to try this procedure a few times in order to resolve the issue as it requires complete attention and precise timing.
1.       Disconnect the power supply from the unit by removing the power cable from the back of the box.
2.       Wait 20 seconds and then put the power cable back in while pressing the 'standby/power on' buttonrepeatedly on the front panel of the box.
3.       Release the standby button as soon as you see a light flash on the front of your box and thenimmediately press the arrow buttons on the front panel quickly and in the following sequence:  Up, Down, Left, Right (please note this is not the order the arrow buttons appear on the box).
4.       Your box should then show the amber light with the green light flashing until the disk re-format has been completed which will take around 60 seconds. The box should return to a solid red light (standby) automatically. If after 2 minutes your box still does not display a solid red light, please repeat steps 1-4.
5.       When you return to the TV GUIDE screen, you will now need to scan for channels to restore your Top Up TV channel logos. To do this, please select Option 4 (set-up) from the Main Menu, followed by option 1 (scan for channels).
6.       IMPORTANT: Once you have completed your channel scan, you will need to select option 5 from the Main Menu (Choose your channels) to re-select all those channel providers you would like Top Up TV to download shows from.
We?re really sorry if you have been affected by this issue and greatly regret any inconvenience this may have caused.
May 04, 2009 | Televison & Video
Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Apr 13, 2009 | Heating & Cooling
Thomson 40KW611S will not come on
the flashing red light is an error code to assist the service engineer to diagnose the fault .the flashing is normally in 2 groups like 2 flashes then a pause and say 5 flashes
Jan 02, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
76 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
