Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Cnt turn key off. its worn. had to disengage clutch to kill engine and disconnect battery cable. Now i cant start it with remote cuz i cant turn it off. Cant start it manually cuz i cant turn it on Do you thinkif I replace the worn key it will work? If I have to get new switch, are they universal? Can I remove it while in the on position? I can remove the key, just cant turn it. Just bought the damn car today. Drove 80 miles to get it. Nice truck but I want to drive it ya know? HELP!
    New Friend:
  • 16 Answers
Try spraying WD40 into the ignition then run the key in and out several times.
This will quite frequently free the lock cylinder up.
Posted on Jan 18, 2013
  • 850 Answers
Try wriggling key while turning steering wheel but if you need to take lock off the steering column remove the battery terminals first!
Posted on Jul 26, 2009
04 malibu will not turn over when connected to battery. new battery same results. however will turn over and start when pos. cable removed and connected to jumper cable.
is your security light on.. a locked padlock on dash???
when you disconnect the battery you "killed" the memory stored in computer like the key codes so car wont start..
need to take to dealer to reprogram computer.. also check your radio i'll bet it also not working... also your remotes
May 15, 2017 | Cars & Trucks
How to disconnect anti theft
It is hard to give a definite answer because I don't know which and how many wires were damaged...Anti theft can be a real HEADACHE.....You can begin by disconnecting battery cables..Use your VIN number for parts,Get new ignition with a programmed factory key from dealer only.....They probably blew certain fuses and or relays when this happened...Or maybe not..Install new ignition connect battery cables..,turn switch on just to check for bad fuses and relays...Disconnect battery again...replace any fuses blown...Connect battery again...( Each time you disconnect battery it resets the computer system and should clear anti theft codes..)..make sure all doors are unlocked by using door remote key fob....Now see if vehicle will crank..If all is done correctly it should start...However I don't know how much damage was done.....It may possibly be too much work to totally disengage anti theft....You could start with removing all fuses and relays related to anti theft but disconnect battery before...I DO NOT RECOMMEND trying to disable the theft system.....You may create more headaches that you want.......Begin by trying what I described just to be safe...!!....
Jan 27, 2015 | 2001 Ford Windstar
How do you disengage the clutch after being left on when turning the engine off?
You can kill the engine with the PTO clutch on and then turn the PTO off before trying to restart because the PTO will auto disengage when the engine switch is turned off. The engine should not start if the PTO switch is on.
Jul 13, 2014 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
My 2001 Dodge Stratus won't start.
Try to install a known good battery. Not just the booster cables. See what happens if everything comes on, then buy a new battery if it works.
Look for all fuses relay switches that say battery or plus on it. Check that they are not burned out . It seems that the current was cut from the car entirely. it can also be the ECU or Electronic Computer Unit.
This is definitely not normal that everything just turned turned off like that.
Mar 14, 2014 | Cars & Trucks
Polaris atv troubleshooting
Clutch not disengageing or engine idle speed to high clutch may not be disengageing from engine speed to high
Jun 04, 2013 | ATVs
Problem with 93 240sx
The first thing to do is have the battery tested and then also clean and remove all corrosion from the battery cables, if they are ion poor condition replace them, if all that is OK then you may have a defective starter motor solenoid, the solenoid is part of the starter. Autozone and others do battery testing for free.
Oct 18, 2012 | Cars & Trucks
Broken clitch cable on 2000 chevy impala...how do u replace it..the wires are broken
see this steps and fix it. God bless you
Clutch Cable Replacement The clutch cable provides a means to "break the drive" between the engine and the wheels. The engine spins constantly, but the wheels do not, so in order to stop a car's wheels without turning off the engine, the wheels have to disconnect from the engine. When the clutch pedal is pressed, the cable disengages the plates, allowing the driver to shift gears or coast without killing the engine.
A failing clutch cable may make the clutch pedal difficult to depress. If the clutch cable fails, the clutch pedal may remain on the floor and not return to its normal position.
To replace the clutch cable, disconnect it from the clutch pedal (usually inside the vehicle) and from the release mechanism or cable attachment that operates the clutch assembly (usually at the transmission beneath the vehicle). A new clutch cable is then installed and adjusted. (The specifics vary according to the vehicle and range from straightforward to very difficult.)
Oct 04, 2012 | Cars & Trucks
Clutch pedel stuck on floor
The clutch master has blown out
Jan 19, 2010 | 1990 Ford F250
Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Jul 16, 2009 | Husqvarna Garden
I was wandering if I need to replace my clutch.
Have you tried adjusting your clutch cable? If the clutch was bad you would rev the engine in gear but the bike would not speed up as it should because the clutch was slipping. But if your cable is out of adjustment pulling the lever may not be disengaging the clutch. You should find the adjustment at the clutch lever, should be a larger locknut and a smaller adjusting screw. You want about 1/2" of freeplay in the lever before it starts disengaging the clutch.
Did it stall with a big **** like you didn't pull in the lever or did it just die? If it died, maybe the sidestand switch is faulting, killing the engine because it thinks your kickstand is still down.
Jan 08, 2009 | 2005 Honda CBR 600 F
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
148 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
