Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Cleaning solution will not dispense
Cleaning solution is not coming out when pushing trigger.
  • 3 Answers
Re: cleaning solution will not dispense
This seems to be a very common problem with the FloorMate, and fortunately it seems to be about the only glaring problem with this otherwise fantastic machine. Worst-case scenario - you will need to merely buy a NEW solution tank for your FloorMate to fix this problem. Here's the mend, on the cheap.
First, do this since it's preventative maintenance that likely is long overdue anyway:
Unplug the machine and remove both reservoirs.
Release the handle as if you were about to use the machine and lay it all the way down. Do this on a counter top with the brush head over or near the sink, or alternately a kitchen table works fine too, just have plenty of towels or paper towels on hand to catch any liquid.
Push the nozzle release tabs outward and take the nozzle off of the machine.
Press the brush release buttons and remove it as well.
Use an old toothbrush and some dish detergent in the sink to clean all the parts as good as possible internally.
Flip the FloorMate over so the underside of the head is facing up. Check the tiny holes where the brush assembly goes, and verify there aren't any clogged [there shouldn't be since dirt never reaches this area]. That is where the solution dispenses from and is dispersed by the spinning brushes.
Reassemble the freshly rinsed brush assembly and nozzle into the head of the unit and close the nozzle latches.
Now, on to the problem at hand:
What I found was the problem with my FloorMate not dispensing any fluid was that the plunger inside the solution tank was pushed up too far into the body of that tank. It is a little black piece, about 2 inches long, is shaped like a pin, and should descend from that hole about one eighth of an inch or so. Since mine [and likely yours] is up in there too high [mine was flush with the bottom of that hole], when you put the tank back into the FloorMate, the post inside the drain hole in the FloorMate isn't sufficiently reaching your recessed plunger to push it up inside the tank which then would allow the cleaner to dispense.
To remedy this, I'll list what I think is the easiest remedy first, followed by how I did it by trial and error:
I recommend using a tartar scraper like the dentist uses, about $2 at Walmart in the toothpaste aisle.
What you're trying to accomplish is to pull the plunger down about an eighth of an inch, as it has slid up further inside the rubber stopper it's attached to than it should be. Don't use too much force when attempting this repair as you might pop the plunger out of the tank completely. If so, see the ALL IS NOT LOST! section further down.
Open the solution reservoir and empty it, and then reinsert the top cap in the event the parts come loose so they won't fall out and go down the drain or otherwise.
Turn the reservoir upside down.
Put the curved end of the tartar scraper into the small drain hole in this reservoir, hook it just above the black plus-sign shaped part of the plunger, and pull down slightly but not too much. You want the two little black plastic "wings" on the bottom of the plunger to extend below the bottom of the drain hole. If you use too much force when pulling, you'll likely dislodge the entire plunger from the rubber stopper and spring that are inside the reservoir. If this happens, ALL IS NOT LOST! :) Just use patience and good lighting, and keep your work area neat and dry, and see two paragraphs down.
Once the plunger is now sticking out of the bottom of the reservoir on its own, fill it up with tap water and hold it upright over the sink. It should not be dripping, but a few drops is not a deal breaker either - this rubber stopper/plunger is to keep the tank from leaking/dripping/draining while you're refilling the tank and putting it back in the machine. A few drops coming out is harmless.
Use the tip of a finger and, holding the tank upright, push up on the plunger. Water should run freely. If so, stand the FloorMate in its locked upright position on the counter or kitchen table and reinsert the tank. If at the sink, put the edge of the brush head over the sink, or if you're at the table place a hand towel under the brushes. Pull the trigger and hold it, and you should see the flow continue uninterrupted until the tank is empty, about 3 minutes [the sink is obviously better, here].
If it emptied completely, your work is done. Pat yourself on the back and go clean your floor! :)
If not, take the tank out and try to pull the plunger down just a little bit further, but not beyond one quarter of an inch from the bottom of the drain hole. Keep doing this until you have satisfactory results.
Note that the solution should dispense SOMEWHAT evenly from the brushes while you're testing this - don't worry if it's running fast out of one or more brushes and only dripping from others. The spinning action of the brushes spreads the solution out evenly. What you want to watch for is that the flow continues uninterrupted until the tank is empty.
Here's how I did this repair during my trial and error investigation:
I used needle-nosed pliers and reached down inside the top hole in the solution tank.
I squeezed the top of the black plunger pin slightly and pushed down until it came out of the bottom of the tank. What remained inside [now loose in the tank!] were the rubber stopper and the spring that sits atop that stopper. I shook them out of the tank and reinserted the spring into the same-size part of the stopper, dropped it into the tank and played a game of skill & chance until I got it back where it was supposed to be and then inserted my tartar scraper into the hole from the bottom, up through the center of the stopper and the spring assembly, and pulled the spring down slightly to get it all back where it needed to be. Challenging but it took less than two patient minutes to do this.
Now turn the tank upside down again and carefully reinsert the plunger into the stopper, but don't push too hard. Make sure you're pushing in a straight line as your goal is to go all the way through the center of the spring and back into the retaining hole above the spring.
Now that the plunger is back home, you'll see it's sticking out about one half of an inch from the bottom of the tank - entirely TOO much!
Using the blunt handle end of my tartar scraper, I pushed the plunger firmly back into place until it bottomed out, causing it to reseat with the rubber stopper. I had to do this about 5 times before only the two plastic "wings" were sticking out from the bottom of that hole. Be careful you don't slip and slice open an artery on you or someone nearby. Perhaps consider using a less-sharp tool for this step if you're not sure of yourself here. Once the plunger is where it should be, see the TESTING section above to make sure you're in the clear.
Since other's solutions posted for this problem are too vague and possibly suggests you modify your FloorMate unnecessarily which will likely lead to future and perhaps irreparable problems, and my solution is very wordy, I'm going to soon make a repair video and post it on YouTube and I'll link to it here in my solution so you can watch instead of read.
Good luck, be careful, and enjoy using your FloorMate once again. :) WHEEEEEEE!!!
Posted on Mar 13, 2009
I had the same problem with my Floormate and was about ready to throw it away until I came here. The posted solutions led to the issue... the black "plunger" being pushed too far into the solution tank, but instead of adding height to the post, or pulling the plunger back out through the bottom, I simply pushed the plunger back down from the inside of the tank. I opened up the tank and used a screwdriver to push the black plunger back into place. Taaa Daa! I love my Floormate once again.
Posted on Mar 17, 2009
Look a little further on this site and a few solutions have been posted already. I can't find where they are but I saw the responses from other users saying how great this site is after the read the solution.
The problem seems to be the plunger on the bottom of the solution tank. The tank does not go down enough to allow the plastic post on the cleaner itself to push the plunger up to allow solution into the machine.
What I did to solve this is I fitted a small piece of rubber hose (about 1/16" inside diameter and 3/8" to 1/4" long) around the post to help push the plunger open once the tank is seated. It worked! I just happened to have a piece of rubber hose laying around and you may not. So just try to attach something on the post to push the plunger up!
Good luck.
Posted on Dec 28, 2007
0 characters
3 Points
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
Clean water and solution will not dispense
This is an unusual problem. The most likely reason is that the supports inside the upper handle grip have broken, and when you squeeze the trigger, the rod that opens the reservoir assembly is not pushing open the valve. If you remove the upper tank, and look behind it, you should be able to see the end of the actuating rod sitting on top of a rubber valve assembly. Squeeze the trigger and watch the rod to see if it pushes down on the valve. If it doesn't, the upper handle grip will likely need replacement. If it does push down on the rubber seal, the reservoir assembly has probably failed and may need replacement.
Jun 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I posted my problem earlier today that I was having with my Bissell Little Green Machine not dispensing solution, but sucked up no problem. Someone said that the most common problem was a blockage. We put...
Okay. I fixed this on mine. Undo the screws on the handle, right by the trigger. You pull the tubes off the little valve. Push on the button and see if you can blow through the valve. If not, push a pin around in the valve (with it pushed into the open position) until you can blow through it easily. Then flush it out with water. May take a couple tries. Then put it back together. Make sure you run clean water through it before putting it away. I think the solution tends to dry inside it. The machine never liked cheap cleaning formula.
Jan 12, 2010 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Detergent constantly dispenses
I would check to see if the trigger is still pluged in it sound as if the trigger is not pluged in or it is hung up.
Jan 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Here is a link, don't know if it will work for you or not:
But you put you cleaning solution along with hot water in the upper tank, the bottom tank sucks up the water as you clean. Pull the trigger to dispense clean while pulling it back towards you, push it forward and repeat until done. If that link doesn't work, you can call Bissell and order a operator manual.
Mar 17, 2008 | Bissell 1770 Quicksteamer II Upright...
Clean water tank
Will the water come out of the tank when you depress the valve at the bottom og the tank? The tank sits on a resevroir asm., is the seal on it, black and round. Inside the handle is a rod, so when you squeeze the trigger, it pushes onto the reservoir to release the water, check to be sure it is, if not then you have a problem inside the handle or a bad reservoir asm. is bad.
Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
652 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
