Question about Acer 91.63X07.001 Keyboard
My 2 and ' keys are swapped
When i press shift and "2" i get "@" and when i press shift and " ' " i get " " " (boy that was confusing) this happend after a "fatal error" and had to compleatly whipe my pc and reinstall everything as if it had just come out of the box i did everything my dusty manual told me to but now i have the above problem i forget how many times my e-mail address has read "hotmail instead of @hotmail thanks in advance
Ian Hart
  • hart_ian Jul 26, 2009
    click on start
    now click on control panel
    now click on regional and language (XP)
    then on the country drop down select English (united kingdom) then apply and your " and @ should be where they show on your keyboard
  • 530 Answers
Friend, first eject the keyboard after 10 seconds then install again.2nd clean the keys
Posted on Jul 26, 2009
How to find derivatives using fx115-es
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X
Oct 29, 2010 | Casio FX-115ES Scientific Calculator
Im not sure on how to caculate derivatives on the calculator, help would be appreciated
If you do not want to specify a tolerance just the last comma and tol.
Example : Calculate
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
1999 siverado 4wd problem..started having problems coming out of 4wd, pushed 2wd dash indicator said 2wd but not in any gear. put in park, got grinding gear sound shut off engine restarted 2wd active now....
sounds like it might be an encoder moter, but the best thing you can do is take it to a good transmission shop so they can hook up their reader and find out for sure
Feb 06, 2010 | 1999 Chevrolet Silverado 1500
" and @ have swapped buttons on the keyboard
Bad keyboard config - follow this
http://www.vistax64.com/tutorials/103844-keyboard-input-language.html
Jan 16, 2010 | HP Compaq nx6110 Notebook
Some keys on my Dell D610 have swapped their functionality when the shift key is pressed - @ and " in particular. Can I swap them back?
Go into Control Panel, Regional and Language Options, Languages Tab, Details Button, Change Default Input Language to English - US, and remove any Keyboards listed that are not English US. Most likely you have set a French Input as a default. Once chnages are made, log out of Windows and log back in.
Jan 06, 2010 | Dell Latitude C600 Laptop Keyboard 47NVF
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
Thus
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
My keyboard letter types wrongly to type @ I have to press shift and 2
UK keyboards use a different key for @.
If you wish to change the keyboard layout, you can do this by right clicking on your taskbar and select "language bar". When this is done, right click on the keyboard symbol and select "settings". Change the default language (to UK) and your keyboard will type correctly.
Jul 18, 2009 | Gateway 7001433 Keyboard
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Acer 91.63X07.001 Keyboard Logo
192 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
